Darcy-Forchheimer law for specifying Porous Zones
Like Tree25Likes
Old   July 30, 2010, 06:53
Default Darcy-Forchheimer law for specifying Porous Zones
usn
Ger_US is on a distinguished road
I would like to use Darcy-Forchheimer law for specifying Porous Zones in Exhaust System application. But I am confused with coordinate system specification. Can anyone please explain what is e1 and e2?
and I have the values
a = 9.367
b = 1.029E7
alpha = 0.5 * a * density [kg/m^4]
beta = viscocity * b [kg/m^3s]
How can I calculate d and f parameters from the above data?
My guess: d= beta/viscocity [1/m^2]
f=alpha/density [1/m]
Am I correct?
if not, please tell me how to calculate d and f parameters.
thank you in advance
FelicityNWU likes this.
Ger_US is offline   Reply With Quote
Old   July 30, 2010, 08:35
VdG
Vincent de Graaf
VdG is on a distinguished road
e1 and e2 are the vectors that are used to specify the porosity. In the porousZones file, you have to specify three components of f and d. The first component is in the direction of e1, the second in the direction of e2 and the third in the direction perpendicular to e1 and e2. An example can be found in tutorials/incompressible/porousSimpleFoam/angledDuctImplicit.
Furthermore,
f=2*alpha/density [1/m]
VdG is offline   Reply With Quote
Old   August 3, 2010, 04:30
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Furthermore,
Note there is also useful little trick in darcy/forchheimer specification: since negative coefficients are physically meaningless, they can (mis)used to specify a multiplication factor for strongly anisotropic porous media. This can be quite convenient.
Ali_petroleum likes this.
olesen is offline   Reply With Quote
Old   August 3, 2010, 05:34
usn
thank you very much for your replies...here I am giving my data...can anyone please tell me e1 and e2 vectors are correct...I attached my porous part file (I gave not fully because it is confidential)
coordinateSystem
e1 (1 0 0);
e2 (0 0 1);
Darcy
d d [0 -2 0 0 0 0 0] (1.029e7 1 1);
f f [0 -1 0 0 0 0 0] (0 0 0);
Thanks
Old   August 3, 2010, 05:42
VdG
Vincent de Graaf
Hi Ger_US,
you have specified a Darcy resistance in x-direction, and virtually no resistance in y- and z-direction. If your intention is to model an anisotropic medium, this might be correct. Note that for isotropic media, all three components of d (and f) should have the same value.
Rojj likes this.
Old   August 3, 2010, 06:44
Mark Olesen
Originally Posted by Ger_US View Post
coordinateSystem
e1 (1 0 0);
e2 (0 0 1);
Darcy
Thanks
The e1/e2/e3 are the axes (x/y/z) of the local coordinate systems. There are some details here:
http://foam.sourceforge.net/doc/Doxy....html#_details
You may also wish to specify the 'origin' of your local coordinate system.
BTW: in you Darcy term, you have close to no resistance in the local y/z directions, but a fairly large one in the x-direction -- what type of porous media should this be?
Old   August 3, 2010, 09:47
usn
I think I am wrong...that is ceramic porous media...
this is information which I have
a = 9.367
b = 1.029E7
alphax = 0.5 * a * density [kg/m^4]
betax = viscocity * b [kg/m^3s]
alphay=1e6
betay=1e6
alphaz=1e6
betaz=1e6
viscocity=1.663e-5 kg/ms
density=0.61935 at Inlet
coordinateSystem
e1 (1 0 0);
e2 (0 0 1);
Darcy
d d [0 -2 0 0 0 0 0] (1.029e7 (6.01e10??) (6.01e10??));
f f [0 -1 0 0 0 0 0] (18.367 (?) (?));
please tell me if anything wrong because I am new to OpenFoam and CFD
I forgot to mention that it is anisotropic medium
Thanks
Old   August 3, 2010, 10:02
VdG
Vincent de Graaf
from the description I assume that the medium has a certain resistance in the x-direction (d = 1.029e7, f = 18.367) and is impermeable in the other directions. My usual approach to this situation is to set the y- and z-resistance to a finite but much larger value than the x-resistance. Typically, I choose to set the y- and z-components of f to 1000 times the x-value. In your case, this would become:
f f [0 -1 0 0 0 0 0] (18.367 18e3 18e3 );
Old   August 6, 2010, 04:33
usn
as you suggested I tried without success. I don't why rho is not stable and bounding p.
Time = 92
smoothSolver: Solving for Ux, Initial residual = 0.00292406, Final residual = 2.10951e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00583214, Final residual = 0.000111279, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.013854, Final residual = 0.000225707, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0369572, Final residual = 0.000357835, No Iterations 1
GAMG: Solving for p, Initial residual = 0.165261, Final residual = 0.00597301, No Iterations 2
time step continuity errors : sum local = 2.06879, global = 0.061706, cumulative = 16.778
bounding p, min: -24708.8 max: 824884 average: 145678
rho max/min : 12.1778 0.0591955
smoothSolver: Solving for epsilon, Initial residual = 0.00295326, Final residual = 9.7231e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00285544, Final residual = 1.06368e-06, No Iterations 2
ExecutionTime = 354.46 s ClockTime = 355 s
Time = 93
smoothSolver: Solving for Ux, Initial residual = 0.00298496, Final residual = 2.15188e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0047816, Final residual = 9.21071e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0134613, Final residual = 0.000221754, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0368796, Final residual = 0.00035114, No Iterations 1
GAMG: Solving for p, Initial residual = 0.171999, Final residual = 0.00616598, No Iterations 2
time step continuity errors : sum local = 2.14248, global = 0.0565349, cumulative = 16.8345
bounding p, min: -28114.3 max: 848170 average: 145624
rho max/min : 12.769 0.0610522
smoothSolver: Solving for epsilon, Initial residual = 0.00294399, Final residual = 9.54477e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00287104, Final residual = 1.05367e-06, No Iterations 2
ExecutionTime = 358.29 s ClockTime = 359 s
Time = 94
smoothSolver: Solving for Ux, Initial residual = 0.00304401, Final residual = 2.19977e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00406858, Final residual = 7.70121e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00943227, Final residual = 0.000157461, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0366639, Final residual = 0.000342336, No Iterations 1
GAMG: Solving for p, Initial residual = 0.179248, Final residual = 0.00637306, No Iterations 2
time step continuity errors : sum local = 2.22181, global = 0.0517805, cumulative = 16.8863
bounding p, min: -29897.8 max: 870334 average: 145566
rho max/min : 14.1506 0.0643263
smoothSolver: Solving for epsilon, Initial residual = 0.00293563, Final residual = 9.37558e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00288938, Final residual = 1.04439e-06, No Iterations 2
ExecutionTime = 362.13 s ClockTime = 363 s
Time = 95
smoothSolver: Solving for Ux, Initial residual = 0.0030967, Final residual = 2.26804e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0035207, Final residual = 6.69516e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00715987, Final residual = 0.000122852, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0362804, Final residual = 0.000331438, No Iterations 1
GAMG: Solving for p, Initial residual = 0.186293, Final residual = 0.00661338, No Iterations 2
time step continuity errors : sum local = 2.31546, global = 0.0470522, cumulative = 16.9333
bounding p, min: -32319.1 max: 893740 average: 145497
rho max/min : 15.0995 0.0689234
smoothSolver: Solving for epsilon, Initial residual = 0.00293385, Final residual = 9.21299e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00290919, Final residual = 1.03662e-06, No Iterations 2
ExecutionTime = 365.96 s ClockTime = 367 s
Time = 96
smoothSolver: Solving for Ux, Initial residual = 0.00314822, Final residual = 2.34295e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00319378, Final residual = 6.15854e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00594322, Final residual = 0.00010551, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0360695, Final residual = 0.000327196, No Iterations 1
GAMG: Solving for p, Initial residual = 0.194211, Final residual = 0.00690557, No Iterations 2
time step continuity errors : sum local = 2.42775, global = 0.0442164, cumulative = 16.9776
bounding p, min: -33417.8 max: 915435 average: 145415
rho max/min : 15.7051 0.0746939
smoothSolver: Solving for epsilon, Initial residual = 0.00293065, Final residual = 9.05813e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00293521, Final residual = 1.03033e-06, No Iterations 2
ExecutionTime = 369.81 s ClockTime = 370 s
Time = 97
smoothSolver: Solving for Ux, Initial residual = 0.00320052, Final residual = 2.42225e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00296225, Final residual = 5.77766e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00504761, Final residual = 8.91875e-05, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0357983, Final residual = 0.000325011, No Iterations 1
GAMG: Solving for p, Initial residual = 0.203505, Final residual = 0.00724398, No Iterations 2
time step continuity errors : sum local = 2.56053, global = 0.045573, cumulative = 17.0231
bounding p, min: -34279 max: 933095 average: 145318
rho max/min : 16.0785 0.0807459
smoothSolver: Solving for epsilon, Initial residual = 0.00291039, Final residual = 8.86735e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00298268, Final residual = 1.0239e-06, No Iterations 2
ExecutionTime = 373.66 s ClockTime = 374 s
Time = 98
smoothSolver: Solving for Ux, Initial residual = 0.00326285, Final residual = 2.48943e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00276879, Final residual = 5.35671e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00437289, Final residual = 7.91479e-05, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0351593, Final residual = 0.000313212, No Iterations 1
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigFpeHandler(int) in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #2 __restore_rt in "/lib64/tls/libc.so.6"
[0] #3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
[0] #4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
[0] #5 main in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
[0] #6 __libc_start_main in "/lib64/tls/libc.so.6"
[0] #7 _start at ../sysdeps/x86_64/elf/start.S:116
[cn-12:16978] *** Process received signal ***
[cn-12:16978] Signal: Floating point exception (8)
[cn-12:16978] Signal code: (-6)
[cn-12:16978] Failing at address: 0x26c00004252
[cn-12:16978] [ 0] /lib64/tls/libc.so.6 [0x3e2842e2f0]
[cn-12:16978] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x3e2842e25d]
[cn-12:16978] [ 2] /lib64/tls/libc.so.6 [0x3e2842e2f0]
[cn-12:16978] [ 3] /server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so(_ZN4Foam10hPsiTher moINS_11pureMixtureINS_19sutherlandTransportINS_12 specieThermoINS_12hConstThermoINS_10perfectGasEEEE EEEEEE9calculateEv+0x4b7) [0x2a95597f77]
[cn-12:16978] [ 4] /server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so(_ZN4Foam10hPsiTher moINS_11pureMixtureINS_19sutherlandTransportINS_12 specieThermoINS_12hConstThermoINS_10perfectGasEEEE EEEEEE7correctEv+0x33) [0x2a955a1303]
[cn-12:16978] [ 5] rhoPorousSimpleFoam [0x41cd9d]
[cn-12:16978] [ 6] /lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x3e2841c3fb]
[cn-12:16978] [ 7] rhoPorousSimpleFoam [0x41ab29]
[cn-12:16978] *** End of error message ***
mpirun noticed that process rank 0 with PID 16978 on node cn-12 exited on signal 8 (Floating point exception).
Boundary conditions:
U:
In: type flowRateInletVelocity; flowRate 0.16448; value uniform (0 0 0);
Out: type zeroGradient;
wall: type fixedValue; value uniform (0 0 0);
P:
internalField uniform 134980;
In: type fixedValue; value uniform 152697;
Out: type fixedValue; value $internalField;
wall: type zeroGradient;
T:
internalField uniform 882.8;
In: type fixedValue; value uniform 879.23;
Out: type fixedValue; value uniform 882.86;
K:
internalField uniform 64.3817;
In: type fixedValue; value uniform 64.3817;
Out:type zeroGradient;
wall:
type kqRWallFunction; value uniform 64.3817;
Epsilon:
internalField uniform 16975.07;
In: type fixedValue; value uniform 16975.07;
wall:
type kqRWallFunction; value uniform 16975.07;
Porous Zones:
Table_2
coordinateSystem
e1 (1 0 0);
e2 (0 0 1);
Darcy
d d [0 -2 0 0 0 0 0] (3.029e7 5.8275e10 5.8275e10);
f f [0 -1 0 0 0 0 0] (20.367 20367 20367);
Table_3
coordinateSystem
e1 (1 0 0);
e2 (0 0 1);
Darcy
d d [0 -2 0 0 0 0 0] (8.808e7 5.8275e10 5.8275e10);
f f [0 -1 0 0 0 0 0] (509.12 509120 509120);
But rho is stable when I used y and z coordinates of porouszones as 1 or 1000
I don't know why rho is not stable for the above Porous Zones parameters.
Can anyone please tell me where I am doing mistake
Thanks
Old   August 6, 2010, 09:04
Chrisi1984 is on a distinguished road
check your discretization in fvSchemes and play a bit with the underrelaxation factors of p.
I realized that they should be really low (about 0.05) in exhaust systems.
And for a first calculation you should take a first order disrectization for the divSchemes (Gauss upwind).
Best regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   August 7, 2010, 00:09
Robert
rob3rt is on a distinguished road
Hi Ger_US
I am wondering how do you get the a & b values? what are they?
I think your f value should be 9.367 instead of 18.367 ?
Kind Regards,
Robert
rob3rt is offline   Reply With Quote
Old   October 20, 2010, 05:11
Marc-Florian Uth
Marc10 is on a distinguished road
Originally Posted by rob3rt View Post
Hi Ger_US
Kind Regards,
Robert
Hi Ger_US!
I have the same question. What are the a & b values.
How can I calculate alpha and beta from a certain Permeability K?
Marc10 is offline   Reply With Quote
Old   March 11, 2013, 04:09
hesam
hesamgh is on a distinguished road
hi
can anyone explain to me what are a,b which are use in equ.?
excuse me if i have mistake in my writing .
hesamgh is offline   Reply With Quote
Old   May 3, 2013, 08:20
Default references
  #14
maddalena's Avatar
maddalena
maddalena will become famous soon enough
a and b are the two coefficients in Deltap = a*v^2 + b*v, which defines the relation between pressure drop and velocity on the porous medium.
see here: https://www.sharcnet.ca/Software/Flu...e233.htm#36964
just as further reference for everybody interested on the subject:
ashvinc9, esujby, manuc and 2 others like this.
maddalena is offline   Reply With Quote
Old   May 12, 2013, 03:56
hesam
thanks a lot maddalena for your answer...
where can i get these coefficient (a,b) for porous medium?
i have an example that have alpha ,beta which have different value in 3 aspects
would you please explain me where can i get them?
a = 9.367
b = 1.029E7
alphay=1e6
betay=1e6
alphaz=1e6
betaz=1e6
Old   May 13, 2013, 02:30
maddalena's Avatar
maddalena
I really cannot understand what you miss on your example. Anyway:
a and b can be calculated with different techniques depending on your input. Simply scroll down the cited post and look for the one which best fit your need.
mad
Old   May 19, 2013, 11:08
hesam
thanks again for your help maddalena
would you mind please tell me one of the way that i can reach to these 2 parameters (a,b)?
i have the velocity inlet and the pressure(zero gradient in of) ,are these values enough to calculate a,b?
i have confused for 2 months to calculate d & f coeff. in open foam ...
mad
Old   August 30, 2013, 09:30
Arrow same problem
  #18
Reza
gooya_kabir is on a distinguished road
did you solve your problem about how to get a and b ? If yes, please help me about that
gooya_kabir is offline   Reply With Quote
Old   November 11, 2014, 04:50
gaetan Hamel
g.hamel is on a distinguished road
I reopen the post because the answers are bugging me.
if we have
and
then d = b and f = a (!?), could somebody tell me if it is the case? Then why define alpha and beta?
I have read a few topics about this question but the definition of D and F remains unclear.
Thanks in advance.
g.hamel is offline   Reply With Quote
Old   November 11, 2014, 11:54
Marco
mkiewat is on a distinguished road
Yes, check out:
http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf
And therefore f = a and d = b
sourav90 likes this.
mkiewat is offline   Reply With Quote
Oscillating velocity and porous zones alberto OpenFOAM Running, Solving & CFD 4 October 28, 2016 03:14
power law flow through porous media Francesca Chiusa FLUENT 1 November 3, 2006 14:30
Help:What's wrong with my porous zones setting!!? jjw FLUENT 2 August 26, 2005 05:16
Permeability for porous zones A8anato_psofimi FLUENT 1 February 17, 2004 13:25
Inputs for porous zones in FLUENT Roel van Os Main CFD Forum 1 September 1, 1998 12:41
