Which solver for "mixing in combustion chamber" problem???
Old   August 17, 2010, 02:59
Default Which solver for "mixing in combustion chamber" problem???
Nilesh Rane
nileshjrane is on a distinguished road
Hello folks,
I am a newbie to OpenFOAM.
I want to simulate the mixing of air and fuel streams in a chamber. its a compressible subsonic flow.
So here is the question. Which solver i should use for this problem? There are just so many compressible solvers that i got confused. Also i want to use RNG-k-eps turnbulence model.
Thanks in advance.
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   August 18, 2010, 09:23
Nilesh Rane
Please someone help.
I am not sure which solver i should use, there are number if options available like rhosonicFoam, rhopsonicFoam, rhoPipmleFoam, rhoturbFoam...I have no idea which of them would be better for mixing problem.
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
Converting a Combustion problem to a plain dispersion problem arnabchakrabarty Phoenics 0 May 10, 2010 09:02
problem about direct solver for sparse matrix ztdep Main CFD Forum 0 August 11, 2006 12:16
can use coupled solver to calculate combustion cfdfans FLUENT 0 November 25, 2003 04:48
