Volumic source term
Hello everybody,
I didn't find any topic on this subject so here I am. I would like to create a volume source term in a fluid region. I have a fluid domain, and I need that a part of this fluid generates a scalar source term, which could be temperature or inert species. Is there any function in OpenFoam for this purpose ? I would use reactingFoam after disabling the chemistry. Thank you all. Aurélien |
volume sources and sink in openFoam
Hello Aurélien,
A good day to you! I am about to face exactly the same problem. I also want to use reactingFoam without chemistry reactions, and apply volume sources and volume sinks. Did you find out how to it? Thank you in advance, Tony |
Aurelien and Tony, sources are discretized by Sp(), Su(), SuSp() operators and in direct manner (fvm::div(phi,T)==b).
Regards. |
Dear Santiago,
thanks a lot for the input! Could you post a code example of a defined source/sink respectively? I need to implement a volume source. If you've ever done something like this, I would appreciate any advice... Best Regards, Tony |
Hi, looking at epsilon equation definition from standard k-epsilon model you have an example:
00223 // Dissipation equation Regards. |
