September 17, 2010, 04:44 |
Problem with total enthalpy
Hait Anatoly
Rep Power: 15 |
Hello everyone!
I have some problem with openFOAM when I try to edit energy model in sonicFoam (hEqu file). I want to change h variable on htot variable (total enthalpy). For that purpose I try to add new field to file createFields.H: 1) volScalarField& htot = (h + 0.5 * magSqr(U)); In that case I took following message during compilation: error: invalid initialization of non-const reference of type ‘Foam::volScalarField&’ from a temporary of type ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ 2) volScalarField htot ( IOobject ( "htot", runTime.timeName(), mesh ), (h + 0.5 * sqr(mag(U))) ); In that case I have no errors during compilation, but I have following error during solving energy equation: valueInternalCoeffs cannot be called for a calculatedFvPatchField on patch BODY_0_ of field htot in file "/home/hait/OpenFOAM/hait-1.6/run/VT5_OF_28/0/htot" You are probably trying to solve for a field with a default boundary condition. I need a help. Thanks a lot! |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls | david39 | OpenFOAM Running, Solving & CFD | 6 | January 18, 2011 11:49 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Help! Total heat transfer rate doesn´t sum to zero | Thomas | FLUENT | 0 | April 6, 2005 02:55 |
