Problem in the flow calculation around airfoil
Old   February 11, 2008, 18:34
Default Dear all, I'm calculating l
swlee
Dear all,
I'm calculating lift and drag for 2d airfoil(aoa is 6 degree). I've already checked and followed the other posts. But, I didn't get a resonable result with icoFoam(or turbFoam) and potentialFoam. My problem was just successed with simpleFoam. Here are the image of my calculation domain and the results with strange velocity at the trailing edge.
This grid was combined by several multi-block sub domains and tested by "checkMesh" utility. checkMesh said like this,
Checking geometry...
Domain bounding box: (-0.5 -2 0) (0.75 1 0.01)
Boundary openness (-1.82318e-18 3.41252e-19 1.9459e-16) OK.
***High aspect ratio cells found, Max aspect ratio: 20349.8, number of cells 2204
<<Writing 2204 cells with high aspect ratio to set highAspectRatioCells
Minumum face area = 8.4915e-11. Maximum face area = 0.00210556. Face area magnitudes OK.
Min volume = 8.4915e-13. Max volume = 2.10556e-05. Total volume = 0.0374918. Cell volumes OK.
Mesh non-orthogonality Max: 85.8056 average: 17.6136
*Number of severely non-orthogonal faces: 176.
Non-orthogonality check OK.
<<Writing 176 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 3.21164 OK.
*Edges too small, min/max edge length = 1.14018e-06 0.0875403, number too small: 2014
<<Writing 2414 points on short edges to set shortEdges
All angles in faces OK.
Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1
All face flatness OK.
Failed 1 mesh checks.
Is there anyone can give me an avice for this problem?
Sung Wook
Old   February 11, 2008, 18:51
Default What is the problem in the abo
swlee
What is the problem in the above calculation?
Does anyone have some advice that I should check?
Sung Wook
Old   February 12, 2008, 00:25
Default Hey Sung, your mesh at the
pbo
Patrick Bourdin
pbo is on a distinguished road
Hey Sung,
your mesh at the trailing edge is kinda rough!
Only 2 cells on the trailing edge (TE) base is not enough. Try to have at least 10-ish cells there.
Also make sure the LE and TE spacings on the upper and lower surfaces are of the order of 0.001*chord or less. If it's not already the case, try as well to pack at least 100 cells on each of these surfaces (with the previous constraints at the TE and LE).
Also the quality of your mesh could easily be improved with a C-grid instead of a O-grid.
If you want to stick to the O grid, use some kind of laplacian smoothing during the grid generation to make it a bit more orthogonal, and/or use at least 3 non-Orthogonal correctors for the pressure equation. You'll get the computation started with 1st order upwind schemes for the convective terms and perhaps some limited laplacian schemes. Later on, if convergence settles in, switch to 2nd order.
Good Luck,
Patrick
pbo is offline   Reply With Quote
Old   September 9, 2010, 11:51
darioth's Avatar
Darío Montes
darioth is on a distinguished road
Send a message via MSN to darioth Send a message via Skype™ to darioth
Hello Sung, Did you fix your problem? I am trying a 0015 with potentialFoam and I have the same high velocities in the t.e.
Any tip will be helpfull
Best regards!!
darioth is offline   Reply With Quote
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 07:22
NACA 23020 airfoil drag and lift calculation. Zmur CFX 2 December 23, 2008 16:35
Oscillating airfoil problem ganesh Main CFD Forum 2 June 27, 2005 13:57
calculation process problem with CFD Hellen Main CFD Forum 2 May 27, 2005 04:06
Parallel Calculation problem Paul CFX 0 August 11, 2003 22:45
