OpenFoam2.3 project path error in Rocks6.1.1 using qsub
Old   December 16, 2015, 11:57
Default OpenFoam2.3 project path error in Rocks6.1.1 using qsub
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hello everyone,
My qsub scripts are not running on our group's server because the node receiving the job looks for the 0, constant, system directories where it it not supposed to.
These scripts used to work some time ago, there has been some updates in this server but our administrators don't see any reason why my scripts are not running any longer.
I am pasting the files I use below in case someone can give me some hints:
run.sh
#!/bin/bash
#$ -cwd
#$ -j y
#$ -S /bin/bash
#$ -pe * 8
#$ -v MPI_BUFFER_SIZE=200000000
# ACTIVATE OPENFOAM ENVIRONMENT
# source /share/apps/centFOAM/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc
# or
. /share/apps/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
# Shouldn't be necessary, since the OpenFOAM should already have this defined
export PATH=$PATH:/opt/openmpi/bin
# FORMATO GENERAL:
# mpirun -np <nProcs> <foamExec> <otherArgs> -parallel > log &
mpirun -np 8 simpleFoam -parallel > log.simpleFoam
I use the following command to submit my job:
>>> qsub -N hembase -q <computation_node> run.sh
And the following error message is received:
Cannot read "/<home>/<user>/system/decomposeParDict"
When that file is at:
/<home>/<user>/OpenFOAM/carlos-2.3.0/run/<project>/system/decomposeParDict
Some time ago I had to create a bashrc file in:
/<home>/<user>/OpenFOAM/bashrc
to overwrite the bashrc file that OpenFOAM installs at the 'etc' directory inside the installation path.
Any hints?
Thanks!!!
aerospain is offline   Reply With Quote
Old   December 16, 2015, 16:09
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Usually I prepend execution of the solver in PBS script with
cd $PBS_O_WORKDIR
and then submit job from case folder. Or you can pass the path with -case solver flag i.e.
mpirun -np 8 simpleFoam -parallel -case $PBS_O_WORKDIR > log.simpleFoam
According to the error, job was executed from your home folder. Guess, it is default location for execution of users jobs.
alexeym is offline   Reply With Quote
Old   December 17, 2015, 02:39
aerospain
Dear Alexey,
Thanksfor your reply!
The job was 'q'submitted from the project folder, the same way it's done when working on a local computer. The error message tells me that the node receiving the job through 'qsub' doesn't know about the openfoam paths. But, if I 'ssh' to that node and run the case locally on it (from the project folder), it's all fun&games.
I am guessing now that the qsub command doesn't "tell" the node to start the job from the folder it was launched.
The policy in our cluster is to always use 'qsub', if we 'ssh' to the node we want to use, the administrators lose the ability to manage properly the system.
By the way, I get no information if I "echo $PBS_O_WORKDIR".
cheers!
Old   December 17, 2015, 11:50
Alexey Matveichev
Did not pay attention to the syntax of configuration comments. So in fact it is SGE and not OpenPBS derivative and variable name should be SGE_O_WORKDIR. Or just use man qsub to figure out name for your job scheduler.
Using qsub in fact a question of optimal cluster resources distribution.
CoCoons Project - Community-driven Documentation on OpenFOAMŪ Technology holger_marschall OpenFOAM Announcements from Other Sources 6 February 2, 2022 14:42
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
