ERCOFTAC conical diffuser for 1.7.1 ?
Old   November 25, 2010, 08:05
Default ERCOFTAC conical diffuser for 1.7.1 ?
Rajshekar
Rajshekar is on a distinguished road
hi,
the case study of the conical diffuser is given at
http://openfoamwiki.net/index.php/Si...nical_diffuser
for BC : to get the source, to compile it and to generate the library is described at
http://openfoamwiki.net/index.php/Si..._OpenFoamTurbo
the procedure is given for 1.4.1 & 1.5 versions.
when i went on to follow the same steps for 1.7.1 version, am encountering problem while compiling it (using wmake libso command). can anyone clarify what changes i have to implement in order to make it work on this version.suggestions and related links would help a lot.
thanking you....
Rajshekar is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 07:49
conical diffuser and turbulence model Markus Main CFD Forum 0 February 24, 2008 07:34
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 21:03
Meshing a 3d conical diffuser david FLUENT 0 June 20, 2005 10:54
conical diffuser design Seung Yi Main CFD Forum 1 August 22, 2000 13:29
