Pressure problems in restarting
Old   January 4, 2011, 22:47
Default Pressure problems in restarting
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi all, I'm facing problems solving a two inlet case, both in icoFoam and interFoam. The case is a vertical tube with an inlet at the top and another inlet at the wall of the tube near the top (between the red spot at right and blue zone), case is axisymmetric. Water enters the domain by the top at 5 m/seg and by the side at 0.5 m/seg, zero static pressure is set at the bottom (outlet). Running with icoFoam from start time to final time things goes well and figure p1 is obtained for pressure. Then if I restart the case only to do one more timestep things goes crazy like in figure p2. Same behavior appears using pressure fixed BC at the side. Using interFoam (which is my objective) with only one phase results are the same (both for U and p BC at the side).
I've checked the elbow tutorial for icoFoam and restarting works fine. That case has two inlets too.
Really I don't know where the problem is, all suggestions are welcome!
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   January 5, 2011, 22:17
Part of the answer is in thread:
http://www.cfd-online.com/Forums/ope...mulations.html
post #6, but plus erasing phi I erased all fields in last timestep but the original ones, in this case p and U.
I don't understand at all why this is the solution, I keep studying.
Regards.
Research Scientist
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Problems with extrapolation of pressure in BC Sergio Main CFD Forum 0 July 17, 2008 09:05
Restarting for problems with moving meshes Maya Siemens 2 October 4, 2002 03:51
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
