using non-orthogonal correction for the laplacian term |
January 3, 2011, 11:45 |
Steven van Haren
Rep Power: 15 |
Dear all,
Hopefully one of you can help me with the following question: If one uses (in fvSchemes): laplacian(nu,U) Gauss linear corrected; which correction is referred to? minimum correction, orthogonal correction or over-relaxed? (as referred to in the thesis of Jasak) Thanks in advance. |
January 3, 2011, 22:29 |
Travis Carrigan
Rep Power: 15 |
I believe this is simply an orthogonal correction, used mainly for highly orthogonal grids (such as high aspect ratio anisotropic tets). |
January 4, 2011, 03:17 |
#3 | |
Steven van Haren
Rep Power: 15 |
Ok, I understand this, I try to use it on polyhedral grids. But do you also know how this orthogonal correction is implemented? Jasak refers to three different possibilities (minimum correction, orthogonal correction or over-relaxed) which are all orthogonal corrections bu with different numerical behaviour. |
January 7, 2011, 23:28 |
Santiago Marquez Damian
Rep Power: 23 |
Until we've studied over-relaxed approach is what is implemented. Take a look of gaussLaplacianScheme.C lines 169-173, correctedSnGrad.C lines 56-108 and surfaceInterpolation.C lines 270-384.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
January 10, 2011, 07:58 |
Steven van Haren
Rep Power: 15 |
Great references to the code lines Santiago!
It is very clear now to me. |
About nonorthogonal correction in fvclaplacian | 7islands | OpenFOAM Running, Solving & CFD | 4 | December 9, 2012 22:54 |
laplacian term in turbulent model | chai | OpenFOAM Running, Solving & CFD | 4 | March 8, 2012 09:28 |
curvature correction term, material derivative of a tensor | volker | OpenFOAM Programming & Development | 7 | June 3, 2010 08:08 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Laplacian viscous stress term in compressible solver | jelmer | OpenFOAM Running, Solving & CFD | 3 | June 23, 2006 07:31 |
