January 13, 2011, 15:54 |
coupling temperature between two solids
Mirko Vukovic
Rep Power: 17 |
I am trying to figure out how to solve a temperature conduction problem between two solids using chtMultiRegionFoam. There are no fluids in this problem. My problem is that I don't know how to couple the temperature across the solid boundaries. I have tried using the solidWallMixedTemperatureCoupled, but that does not work Code:
air_to_plate { type solidWallMixedTemperatureCoupled; neighbourFieldName T; K K; value 293.15; } As the problem in the solver that I am using or in the boundary condition? Thanks, Mirko PS - I am attaching the problem files for a simple 2D problem. |
January 14, 2011, 04:25 |
coupledMatrix
Maria
Rep Power: 17 |
Did you try using the "coupledMatrix" instead? (See conjugateHeatFoam)
Marķa |
January 14, 2011, 09:55 |
#3 | |
maddalena
Rep Power: 23 |
Hi Mirko,
constant/solid1/polymesh/boundary file: Code:
solid1_to_solid2 { type directMappedWall; nFaces 10; startFace 390; sampleMode nearestPatchFace; sampleRegion solid2; samplePatch solid2_to_solid1; offset (0 0 0); } Code:
solid1_to_solid2 { type solidWallMixedTemperatureCoupled; value uniform 300; neighbourFieldName T; K K; } mad |
January 14, 2011, 14:10 |
#4 | |
Mirko Vukovic
Rep Power: 17 |
Yep, it helped me track down an incorrect entry in the changeDictionary/dictionaryReplacement/boundary/X_to_Y. I had incorrectly set the sampleRegion as X instead of Y. I also used the coupling boundary condition compressible::turbulentTemperatureCoupledBaffle (I don't have a clue why that name. Looking at it's .H file the coupling condition looks very general). Mirko |
January 17, 2011, 02:28 |
maddalena
Rep Power: 23 |
Hi Mirko,
could you post the temperature change in time of some points of your domain and compare them with theoretical time variation? I have some doubts on results I have obtained so far... Thank you mad |
January 17, 2011, 09:48 |
link
maddalena
Rep Power: 23 |
January 17, 2011, 11:00 |
#7 | |
Mirko Vukovic
Rep Power: 17 |
Mirko |
January 19, 2011, 17:58 |
#8 | |
Mirko Vukovic
Rep Power: 17 |
(got busy with paperwork) Unfortunately, I managed to break my two-region problem and loose the temperature connectivity across the interface. FWIW I am attaching two archives:
Mirko |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Fluent Ansys temperature coupling | tensun | Fluent UDF and Scheme Programming | 0 | November 14, 2010 05:30 |
high temperature in a coupling simulation | sheintz | STAR-CCM+ | 3 | September 30, 2010 13:56 |
How to set Temperature as heat source in Solids | shahpar73 | CFX | 2 | August 20, 2009 18:51 |
Coupling CFX4 with a solids code | Brett Towler | CFX | 1 | September 20, 2000 20:09 |
