suggestion for thermophysicalproperties for high temperature buoyant flow
Old   March 21, 2011, 14:06
Default suggestion for thermophysicalproperties for high temperature buoyant flow
Fabian Braennstroem
braennstroem is on a distinguished road
I would like to run simple smoke distribution simulation in a ventilated compartement with some buoyant solver. I wonder, if you have a suggestion for the thermophysicalproperties. There is no combustion involved just volume sources for heat and smoke as a passive scalar (using swak4foam).
Up to now, I am using the standard:
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture air 1 28.96 1004.4 0 1.831e-05 0.705;
pRef 100000;
but a better approach would probably be to use Sutherland law for viscosity... unfortunately I do not know, how I can get the values for As and Ts!? Maybe you have a suggestion for even other settings for this kind of pseudo-fire simulation... would be great!?
Best Regards!
Fabian
braennstroem is offline   Reply With Quote
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
why is solid temperature same as fluid temperature on flow simulation ? qihongming FloEFD, FloWorks & FloTHERM 0 May 26, 2009 08:57
Temperature in stagnation flow Wooster CFX 5 April 27, 2007 13:28
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 08:29
Stagnation temperature in free molecular flow Anton Lyaskin Main CFD Forum 2 July 30, 2004 09:09
