Droplet breakup in interDyMFoam - escalation of Courant number
Old   August 13, 2017, 19:28
Default Droplet breakup in interDyMFoam - escalation of Courant number
ashama is on a distinguished road
I am modeling a droplet breakup from the surface of a nozzle (flat surface with inlet channel of some flow rate) - What I am interested to know is the mean time between the breakup of two droplets
I am using an OpenFOAM version for Windows 17.06
The solver is interDyMFoam with dynamic mesh refinement on Alpha field - I used SALOME to make a simple mesh (tets) with local refinement on the inlet nozzle. I know approximately that the breakup radius is ~2.3 mm from the surface, I made intial alpha field of 2.2 mm radius to reduce the time it takes to build up this droplet, then I want to see it getting detached from the surface.
I uploaded the case to google drive
https://drive.google.com/file/d/0B4f...ew?usp=sharing
The problem I have is: when the interface is going to breakup the Courant number jumps very high - if I fixed delta t, if I let it adjustable, it keeps getting smaller and very smaller, what could be the wrong with my model, I am even using the correct solver?Could it be related to the boundary conditions? I would appreciate if someone looks to my 0 directory or the fvScheme ...
ashama is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
