Hypersonic flow rhoCentralFoam
Like Tree1Likes
  • 1 Post By ishaninair
Old   April 7, 2011, 04:38
Default Hypersonic flow rhoCentralFoam
Ishan
ishaninair is on a distinguished road
I tried to simulate a hypersonic flow through a scram-jet engine in rhoCentralFoam but a Normal shock is getting generated as you can see that in the attached picture. Same thing is happening when I tried to use sonicFoam. I really don't know the reason, Please help.
the BC are
pressure:
internalField uniform 139.81;
boundaryField
inlet
type fixedValue;
value uniform 139.81;
outlet
type zeroGradient;
temperature:
internalField uniform 123.12;
boundaryField
inlet
type fixedValue;
value uniform 123.12;
outlet
type zeroGradient;
velocity:
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (1778.711 0 0);
outlet
type zeroGradient;
Thanks
Regards,
Ishan
febriyan91 likes this.
ishaninair is offline   Reply With Quote
hypersonic, rhocentralfoam, scramjet
Finite Rate Chemistry Setup for Hypersonic Flow AdeeMij FLUENT 22 July 11, 2017 10:28
Hypersonic flow Subramani FLUENT 8 May 7, 2007 20:02
catalysis in hypersonic flow Sile Main CFD Forum 0 January 31, 2006 07:00
Multigrid for hypersonic flow Jeff Main CFD Forum 0 October 20, 2002 20:50
Hypersonic flow applied to blunt nosed (ie. 2d bodies) manishkumar Main CFD Forum 1 January 10, 2000 22:36
