unsteady flow over cylinder
Old   July 16, 2013, 09:53
Default unsteady flow over cylinder
achyutan is on a distinguished road
I am reporting problem in unsteady flow over circular cylinder tried using simple and pisoFoam.
I used the converged solution of simpleFoam into pisoFoam. solution appears stable with a Co around 0.2. the forces and the coefficients come out very small. lift coefficient comes out many orders small. I have checked for possible errors in controlDict (Aref, lref etc.). the coefficients remain constant after some time.
I went back to view the simulation of the fields and found no change happening after a few time steps.
I am attaching my case here with only 0, forces, forceCoeffs directories. Could someone find out the error ?
regards,
achyutan
achyutan is offline   Reply With Quote
Old   July 17, 2013, 06:20
sorry that i didnt attach system directory for viewers to check controlDict.
I have attached now.
I would really appreciate replies here as nothing comes to my mind on this.
waiting for response..
achyutan
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 01:12
Flow induced vibration of a mobile cylinder Hooman Main CFD Forum 0 December 31, 2010 08:48
Flow past 2 smooth circular cylinder slip FLUENT 0 July 8, 2010 18:45
Unsteady simulation on the flow around Naca0012 Peter Pan Zhang FLUENT 2 June 11, 2006 19:53
