Source Term in Canyon Simulations
Old   May 27, 2011, 06:28
Default Source Term in Canyon Simulations
Abhinav Sharma
asharma is on a distinguished road
I'm trying to replicate wind tunnel experiments done for pollutant dispersion inside isolated street canyon. Most of the work is based on the set up published by Meroney et al (1996). I'm having trouble (physics) incorporating the source for the scaler pollutant inside my domain. I've modified pisoFoam to incorporate scaler transport as
 fvm::ddt(T)
	  + fvm::div(phi, T)
	  - fvm::laplacian(turbulence->nut()+DT, T)
          source
I've also incorporated nut() value to account for turbulent diffusion. Presently i'm using funkysetfields ( part of swak4foam) to specify source as a constant value in cells where the pollutant is introduced and thus is fixed throughout the run. However my prof tells me this is wrong, as it doesn't fit the physics of the problem. Rather i should force the value of my scaler T to be constant at those points rather than specify source. Is this correct? If so how do i go about this?....
Regards,
Abhinav
asharma is offline   Reply With Quote
Old   May 28, 2011, 02:27
Alberto Passalacqua
You can use setValues to do what you ask for. Please, search on the forum to see how to use it.
Alberto Passalacqua
Old   May 13, 2015, 03:51
Yan Wang
wayne14 is on a distinguished road
 fvm::ddt(T)
	  + fvm::div(phi, T)
          source
Regards,
Abhinav
Hi, I am doing something similar. Could you explain why using funkysetfields doesn't fit the physics?
Thank you!
wayne14 is offline   Reply With Quote
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
Read txt file and import values to source term. Constantine Fluent UDF and Scheme Programming 40 July 21, 2016 17:20
How to write source term into scalar Fiel JimKnopf OpenFOAM Programming & Development 0 March 23, 2011 05:59
Is it possible to use divergence in the source term of an scalar transport equation? jannnesss CFX 0 January 8, 2010 19:53
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
