regaeding error while running rhoSimplecFoam
greetings bruno and everyone ,
i am trying to simulate my case of cold flow simulation using the rhoSimplecFoam solver but after some time of run it ends with the following error .. can you plz help me to understand where i am doin wrong ? thanks in advance :) Code:
Time = 43 |
Greetings yash.aesi,
Not much information to work with. But from the output you've showed: Quote:
Best regards Bruno |
thanks bruno ,
i wl try to check BC's :) |
1 Attachment(s)
helo bruno ,
i tried to check my BC's. Now after giving a run its goin fine but i think the problem is not solved yet as the point you mentioned in last post about the pressure is not solved yet . The output is showing as (without giving error ): Code:
Time = 298 thanks alot in advance :) |
Hi Sonu,
From what I can see, the pressure in the outlet should not be defined as being of type "calculated". Because that way you have an undefined boundary on the outlet, since you say that the velocity is of type "zeroGradient". For ideas on what the boundary conditions should be, see the tutorials on OpenFOAM and see the link "Boundary Conditions" on this page: http://foam.sourceforge.net/docs/cpp/index.html Best regards, Bruno |
Greetings Bruno ,
thanks bruno for suggesting these link which are useful to me for better understanding . but i already changed the outlet BC to zeroGradient then simulation keep on running its not converging . Rite now i dnt have output to show but show you other day . Regards , sonu |
helo
here is what is shown in the output : Code:
Time = 1499 Code:
dimensions [1 -1 -2 0 0 0 0]; Regards , Sonu |
outlet BC for pressure should be fixedValue,assign a back pressure there.
1 Attachment(s)
greetings Ehsan and bruno ,
i changed my pressure outlet BC's from zeroGradient to fixedValue but now again its giving error : Code:
Time = 19 thanks |
Hi Sonu,
First, please follow the instructions on my second signature link, for when you need to post output or code, namely: How to post code using [CODE] Second, you still have epsilon values that are outside of the normal zone of operations, namely: Code:
epsilon, min: -0.164911 Last but not least, you should not jump directly to such high flow rates. With OpenFOAM, as well with anything you don't know well enough, the approach is to not jump directly into the final case set-up, because it's very unlikely that you will succeed to have a working simulation. And in that situation, you'll have too many possible reasons for the simulation to not work, making it nearly impossible to fix all of the problems in a single step. Therefore, you should gradually evolve from the simplest form of your problem, increasing the level of complexity one detail at a time. Best regards, Bruno |
Some errors and doubts
I was running a compressible LES simulation when it stopped with a similar or the same error, displayed just below.
Mean and max Courant Numbers = 0.0327681 0.0831581 I also checked my mesh with the command checkMesh, the output was Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // And, as I see from the residuals and Courant number, all of them seem alright. Resuming, when I run simulations with two computers, this errors happens. So is there a problem, when parallel computing is being performed with processors of two machines ? I mean the communication between them ? |
Greetings guilha,
To assess if the problem is related the communication between the two machines, try running with 16 cores on each machine, therefore having 32 cores in total. This way you can isolate if the problem is due to using too many cores, or a bad decomposition or if it's related to the communication. In addition, there are a few other things that can affect this:
Bruno |
Hello Bruno and all other FOAMers, thanks for your help and patience
I did not have time to test the communication between the machines. Now, following your list: 1 - Yes, I have cyclic patches, my case is almost two dimensional and LES; 2 - The "commsType" is set with nonBlocking. If I change do I have to compile anything ? 3 - I know it not, I talked to the administrator and we both do not know, but probably it is because I do not understand what really means the file sharing, however it seems not to be NFS as she said we did not use it; 4 - The communication between the machines is Ethernet. 5 - It is ok, and the output is just below (checkMesh with more options). Code:
/*---------------------------------------------------------------------------*\ http://www.cfd-online.com/Forums/ope...ple-cores.html I do not need to do the decomposition with parallel computing but it gave me the alert, is the problem in my decomposition ? I have been doing it by simply typing decomposePar -force, and if I wish to do it with more processors do I have to change anything in the command ? I ask it because I thought I could simply write on the script the number of processors used to do the decomposition. Although I am not using scripts to do the decomposition. And to finish, the two cases I was running, now on SINGLE MACHINES, one of them stopped with almost the same erros (almost, because I checked the messages and they have very few differences). I must remember that the two cases are the same, but one with a more refined mesh. And the one that had given the error is the most refined case, the time of simulation at which appeared the error is almost the same as a particle at the speed of U0 have traveled the distance of the whole domain 2 times. The other case, I am running to get more samples for statistic issues, and until now no problems. So I am totally dizzied. It does not seem to be anything unphysical, I mean the residuals and Courant (and the other coarser mesh gave great results), the new error message is this one: Code:
Mean and max Courant Numbers = 0.0354678 0.0909748 |
Hi guilha,
Either your case is 2D or it isn't. In OpenFOAM, "2D" is when we use front and back patches defined as "empty" and there is only one cell thickness in the Z direction. As for LES in 2D... I vaguely remember that it's not exactly a good idea... because the turbulence is actually 3D. But then again, I vaguely remember that OpenFOAM has got one or two tutorials working with LES in 2D. Quote:
Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() Problem here is that there is no clear indication of which operation might have given a division by zero. I would choose to write frequent time snapshots near the crashing time location and then visually inspect where the fields are getting high or rather low values. Best regards, Bruno |
Hello Bruno, thank you for your analysis. I have been too much busy lately.
The test between the machines, I did not do because I can not use x processors of one machine and y processors of the other. However, I did a test (the case is the same, only has a bigger time step), and I run it in a single processor, it failed here: Code:
Mean and max Courant Numbers = 0.200668 0.571628 About my simulations, they are LES 3D, of course. What I meant for almost 2D, was the type of flow, which is quasi-2D. For the cases where my time step is smaller than the one I posted in code, and running in parallel, the errors are random. And I can not have the results stored since it leads to a lot of memory usage. But for the last test (relatively big time step) I did (which was in a single processor), the error is not random, I run the case twice and confirmed it. From the post processing, my velocity grows in a sharp corner, and this is the reason why Courant increases, but I think it is compatible with the perfect fluid solution. But in this simulation, I think it gets unstable due to the Courant increase, that is with a smaller time step it might be bounded to the stability limit. Also I saw the function, which you told me about, the ePsiThermo. Where there is an alpha. For certains boundaries conditions (alphaSGS, muSGS and muTilda), I used a standard one (as I could not find in the literature any value for these variables) which I saw on an OpenFOAM tutorial, and they are essentially 0. Regarding the cyclic patch, in this link http://www.cfd-online.com/Forums/ope...tml#post241413, I think I have this in the computer, Code:
//- Keep owner and neighbour on same processor for faces in patches: |
Hi guilha,
Higher values should only be used if you know what you are doing ;) Quote:
preservePatches ( Bruno |
Good evening,
I am again in this thread because recently I have had a wierd error. When I run my case in 16 processors or 24 (the cases tested), no problems appear, however with more processors like 30, 32 or 64 (the cases tested) it appears this error Code:
Hi guilha,
It could be a problem in the installation of OpenFOAM on one of the machines. Try running checkMesh in parallel, the same way you run rhoCentralFoam. And a few questions (I don't remember the details):
Bruno |
Bruno thanks a lot for your replies and all the support.
Running the checkMesh in parallel gives an error yes Code:
/*---------------------------------------------------------------------------*\ I have cyclic boundary conditions. The decomposePar I think it works perfectly fine, the output is for the 32 processors Code:
Processor 0 |
In the previous post the checkMesh output was shown without the decomposition, after decomposing there is an error
