Foam IOStream error for InterDyMFoam parallel run - doesn't write uniform/time files.
Old   June 29, 2011, 19:11
Default Foam IOStream error for InterDyMFoam parallel run - doesn't write uniform/time files.
Dominic Piro
djpiro is on a distinguished road
I am getting the following error while running InterDyMFoam on a cluster:
[6] --> FOAM FATAL IO ERROR:
[6] error in IOstream "/.../wedge10_3_2D_ultraFine_par_1.5_8/processor6/0.0132/uniform/time" for operation Ostream& operator<<(Ostream&, const char*)
[6]
[6] file: /.../wedge10_3_2D_ultraFine_par_1.5_8/processor6/0.0132/uniform/time at line 4.
[6]
[6] From function IOstream::check(const char*) const
[6] in file db/IOstreams/IOstreams/IOstream.C at line 93.
[6]
FOAM parallel run exiting
I have checked, and the uniform directory has been created for each processor at time 0.0132, but nothing has been written. I have tried this simulation multiple times, and each time it fails at the same time step with the same problem. Does anyone have any ideas as to what would cause this error?
Thanks,
Dominic
djpiro is offline   Reply With Quote
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
MPICH Parallel Run Error on the Windows Server2003 Saturn CFX 3 August 29, 2006 08:42
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
