differentiation in one direction
Old   August 1, 2011, 18:39
Default [solved]differentiation in one direction
Mieszko Młody
ziemowitzima is on a distinguished road
Dear Foamers,
Does anyone of you know what is the best way to dicsretize following problem:
we have: f(x,y) -- scalar function
we need: f_xxxx
(fourth order) differentiation but only in one direction.
i.e.
laplacian(f) = f_xx + f_yy
but I need only f_xx (in fact I need f_xxxx)
Thanks
ZM
ziemowitzima is offline   Reply With Quote
Old   August 2, 2011, 01:55
Fabian
gautcho is on a distinguished road
You should use a difference quoutient, like you have propably seen for f_x. You can perform the difference quotient "four" times or you can have a look here (they have already done it for you):
http://en.wikipedia.org/wiki/Difference_quotient
Probably it should be the best for you to read the whole article, but you can also jump ahead to:
http://en.wikipedia.org/wiki/Differe....C5.83th_Order
gautcho is offline   Reply With Quote
Old   August 2, 2011, 11:10
Mieszko Młody
Thanks
This I know.
I didn't put it explicit in my question but I need to know how to make it in OpenFOAM.
-Best
Old   August 2, 2011, 17:52
Mieszko Młody
so far I found such explicit solution:
volVectorField gradT=fvc::grad(T); // (T_x, T_y)
volScalarField Txxxx = gradT.component(0); // T_x
gradT = fvc::grad(Txxxx); // (T_xx, T_xy)
Txxxx = gradT.component(0); // T_xx
gradT = fvc::grad(Txxxx); // (T_xxx, T_xxy)
Txxxx = gradT.component(0); // T_xxx
gradT = fvc::grad(Txxxx); // (T_xxxx, T_xxxy)
Txxxx = gradT.component(0); // T_xxxx
Maybe someone have some better idea ?
Is it possible to descritize T_xxxx implicitly ?
-ZM
Old   August 4, 2011, 12:24
Mieszko Młody
It seems that problem can be solved (after Akidess suggestion ):
"... it sounds like you want anisotropic diffusion - why not just pass a diffusion coefficient tensor to laplacian instead of a scalar?..."
http://www.cfd-online.com/Forums/ope...-operator.html
So,
x - direction diffusion:
DTe1D DTe1D [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 0 0 0 0 0 );
x,y and - directions diffusion:
DTe3D DTe3D [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 3e-02 0 0 0 3e-02 );
for f_xxxx it can be done as follows :
suppose we have equation f_xxxx = g(x,y),
substitution: h = f_xx
so we have two "one-directional" Poison equations to solve:
h_xx = g(x,y)
f_xx = h(x,y)
in OF:
fvm::laplacian(DTe1D, h) == g
fvm::laplacian(DTe1D, f) == h
one direction diff
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 13:42
Accelerate flow in one direction JanR FLUENT 2 January 19, 2011 15:52
[ICEM] Changing edge direction la7low ANSYS Meshing & Geometry 2 June 7, 2010 13:26
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
direction of porosity shin FLUENT 0 February 23, 2005 16:17
