GGI in Parallel error
Old   November 9, 2011, 06:31
Smile GGI in Parallel error
任芸
renyun0511 is on a distinguished road
hi, foamers,
I am simulating the pump inner flow with MRFSimpleFOAM (OpenFOAM-1.5-dev) on my PC successfully. Currently, I am experiencing some difficulties with parallelising my own GGI case on the HPC with MRFSimpleFOAM (OpenFOAM-1.5-dev),and I need your help.
As far as I was aware the GGI should work in parallel as long as the setBatch in system are defined before using the decomposePar utility.
I put the following instructions in setBatchDict:
faceSet interfacesuc_zone new patchToFace interfacesuc
faceSet interfaceimp1_zone new patchToFace interfaceimp1
faceSet interfacevol1_zone new patchToFace interfacevol1
faceSet interfaceckyc_zone new patchToFace interfaceckyc
quit
where, my boundary are:
wall
type wall;
nFaces 88020;
startFace 2294747;
wallhgb
type wall;
nFaces 28584;
startFace 2382767;
wallqgb
type wall;
nFaces 28448;
startFace 2411351;
interafcevol1
type ggi;
shadowPatch interfaceckyc;
bridgeOverlap false;
zone interfacevol1_zone;
nFaces 1446;
startFace 2439799;
interfacevol
type ggi;
shadowPatch interfaceimp;
zone interfacevol_zone;
nFaces 22196;
startFace 2441245;
interfacesuc
type ggi;
shadowPatch interfaceimp1;
zone interfacesuc_zone;
nFaces 2368;
startFace 2463441;
interfaceimp1
type ggi;
shadowPatch interfacesuc;
zone interfaceimp1_zone;
nFaces 1120;
startFace 2465809;
interfaceimp
type ggi;
shadowPatch interfacevol;
zone interfaceimp_zone;
nFaces 8680;
startFace 2466929;
interfaceckyc
type ggi;
shadowPatch interafcevol1;
zone interfaceckyc_zone;
nFaces 748;
startFace 2475609;
wallimp4
type wall;
nFaces 2226;
startFace 2476357;
wallimp3
type wall;
nFaces 2238;
startFace 2478583;
wallimp2
type wall;
nFaces 2226;
startFace 2480821;
wallimp1
type wall;
nFaces 2262;
startFace 2483047;
outlet
type patch;
nFaces 748;
startFace 2485309;
inlet
type patch;
nFaces 3468;
startFace 2486057;
and then, I using the following commands:
setSet -batch setBatch
there is a error on the screen:
Create timeCreate polyMesh for time = 0Time:0 cells:1196068 faces:2489525 points:249609 patches:15
Reading commands from file "setBatch"
Cannot open file "setBatch" From function setSet
in file setSet.C at line 749.FOAM exiting
Does anyone know the reasons for this?
regards,
Yun Ren
Jiangsu University, China
renyun0511 is offline   Reply With Quote
Old   November 9, 2011, 21:56
Smile
任芸
I have solved this problem by moving the setBatch file in the case folder from system folder. After typing:
setsToZones -noFlipMap
I can see 4 more new faceZones in constant/polyMesh/sets was created, which are interfacesuc_zone,interfaceimp1_zone,interfacevol1 _zone,interfaceckyc_zone
Further, my system/decomposeParDict contains the following:
numberOfSubdomains 4;
method simple;
simpleCoeffs
n (2 2 1);
delta 0.001;
globalFaceZones(interfacesuc_zone interfaceimp1_zone interfacevol1_zone interfaceckyc_zone);
hierarchicalCoeffs
n (1 1 1);
delta 0.001;
order xyz;
metisCoeffs
processorWeights
1
1
1
1
manualCoeffs
dataFile "";
distributed no;
roots
then , processor0,processor1,processor2,processor3 were presented in my case folder. Until now, I think everything runs OK. However, when I run this case in parallel by typing:
mpirun -np 4 MRFSimpleFoam -parallel
there is an error, here are:
see the attachment
I don't know if there is another codes i should add into my case,does anyone help me?
appreciate,
Yun Ren
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
