October 4, 2011, 23:03 |
Freestream boundary condition
Lee Yin Jen
Dear FOAMers,
Hi, I'm pretty new to OpenFOAM and CFD. One question I have is regarding Freestream boundary condition - how exactly does it work? Specifically, I tried to run an external aerodynamics case, using fixedValue for velocity, nut and nuTilda at outer boundary, zeroGradient for pressure at outer boundary; simpleFOAM, S-A turbulence. The results are rather unphysical and diverging. However, following the airfoil example for simpleFoam and using freestream boundary condition, the simulation seems to be more reasonable and without divergence. My question is, how does freestream boundary condition differ from fixed values? Thanks, FOAMers! |
October 7, 2011, 10:54 |
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
Hello Lee,
The freestream BC has the type inletOutlet meaning that it looks locally (for every face of the patch) at the mass flow rate. And if the flow is going outside the boundary will be locally zerogradient, if it is going inside the boundary will be locally fixedValue. The freestreampressure BC is a zeroGradient BC but it fixes the flux on the boundary to be rho*Sf*freestreamValue. Good luck Frederic
Frederic Collonval Technische Universität München Thermodynamics Dpt. |
October 8, 2011, 10:37 |
Lee Yin Jen
Thanks, Frederic! Think I get the point now...
December 11, 2012, 11:29 |
Malik
Thank you for the explanation. If i am right the difference between a freestream BC and a fixedValue BC is that for fixed value there are constraints on each vector of the velocity field, while with freeStream we have a constraint only for the flux. This is why the solution sounds more physical ? |
December 19, 2012, 21:18 |
Lee Yin Jen
Hi, malaboss
Freestream BC is like a hybrid fixedValue and zeroGradient boundary condition. It behaves like a zeroGradient when fluid is flowing out of the boundary face, but behaves like a fixedValue when fluid is not flowing out. So, instead of fixedValue that imposes its constant value regardless of situation, freestream is more flexible, doing whatever is more physically realistic, so to say. |
October 8, 2014, 07:05 |
Mieszko Młody
I am using currently freestream BC for the flow in the tunnel (channel). Is it an appropriate BC for such flow ? In short, there is large tunnel (3m in diameter) flow is from left to right (inlet, outlet with freestream BC) but inside the tunnel there is additional small inlet with some mass flow specified. thanks |
May 5, 2015, 04:00 |
Rep Power: 11 |
Hi everyone,
Is it possible to use the freestream BC (to simulate a external hydrodynamic case) in 3D. In this case what is the good boundary condition to use for the frontAndBack ? Thanks for answers |
June 4, 2015, 08:03 |
#8 | |
Rep Power: 11 |
Could you explain me what is Sf. In advance, many thanks |
July 7, 2015, 02:04 |
Junshin Park
Rep Power: 12 |
December 19, 2016, 09:08 |
3D airfoil mesh
salman sadeghi
Hi everyone, i import .msh file (3D Cgrid mesh for airfoil in gambit) in openfoam and i got this error: {illegal cell label -1 in neighbour addressing for face 0} is it all about boundary condition?
the main question is haw to define that in 3D gambit to not face this error?or is it possible to import just geometry and mesh without boundary and then define it just in openfoam? thanks all of you in advance |
July 19, 2017, 04:36 |
#11 | ||
Thank you both for the explanation. I want to use freestreampressure but combined with having the pressure prescribed as a value: "Prescribed pressure; with allowed in/outflow reversal" Is this possible in OpenFoam? Thanks, PS: more details: It is a wind engineering in-compressible flow simulation. I have a prescribed inlet velocity BC (Fluctuating Inlet). We usually combine this with a zeroGradient Pressure BC on the inlet. I want to have Inlet/Outlet condition on the Top, Sides and Outlet. However, a pressure value should be described on some boundary. Usually we use a fixedValue 0 for pressure. Is there a way to combine this with freestreampressure? |
August 27, 2018, 00:32 |
regarding difference between freestream and inletoutlet boundary condition
#12 |
ijaz fazil
hi all,
I apologies for reopening this topic after a long time. I have doubt what is the difference between freestream and inletoutlet bC In inletOutlet BC also when the flow is out of the domain it will be zerogradient while the flow is into the domain it is fixed value. Then what is the difference between both condition. |
March 10, 2019, 04:00 |
#13 | |
Jianrui Zeng
Rep Power: 7 |
October 24, 2019, 03:44 |
Inletoutlet also provide same definition
#14 | |
ijaz fazil
hi then what is the difference between freestream and inletoutlet because inletoutlet also same definition, when fluid is going out zerogradient while when the fluid is into the domain fixed value. So what is the difference between two? |
June 5, 2020, 02:54 |
#15 | |
Hailong
Rep Power: 6 |
boundary condition, freestream, openfoam 2.0.x |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
