Nonorthogonal correction
Like Tree8Likes
  • 4 Post By hjasak
  • 2 Post By MichiB
  • 2 Post By MichiB
Old   August 8, 2008, 09:05
Default Where can I find the piece of
Maka Mohu
maka is on a distinguished road
Where can I find the piece of code that describes how the non-orthogonal correction is implemented in a solver like icoFoam? Thanks.
maka is offline   Reply With Quote
Old   August 9, 2008, 06:17
Default The code for icoFoam is in $
Ola Widlund
olwi is on a distinguished road
$FOAM_APP/solvers/incompressible/icoFoam
/Ola
olwi is offline   Reply With Quote
Old   August 9, 2008, 14:33
Default yes, I have read the code but
Maka Mohu
yes, I have read the code but the implementation of how the non-orthogonal correction is implemented is internal and does not show on the icoFoam.C. I read that non-orthogonal grid will result when treating a laplacian term in some terms that will be treated explicitly. May be that is why there is a loop. But I'm looking for the details of how such terms are implemented in openfoam.
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rUA, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
Thanks.
Old   August 9, 2008, 16:49
Default 42
nadine
42
Old   August 9, 2008, 17:58
Default Try: - my Thesis for a refere
Hrvoje Jasak
Try:
- my Thesis for a reference
- gaussLaplacianScheme.C, line 165
fvm.source() -=
mesh.V()*
fvc::div
gammaMagSf*this->tsnGradScheme_().correction(vf)
)().internalField();
where the correction comes from the snGradScheme, eg. correctedSnGrad.C, line 89:
mesh.correctionVectors()
& linear
typename
outerProduct<vector,>::cmptType>::type
>(mesh).interpolate
gradScheme<typename>::cmptType>::New
mesh,
mesh.gradScheme(ssf.name())
//gaussGrad<typename>::cmptType>(mesh)
.grad(vf.component(cmpt))
Clear?
Hrv
fumiya, Tobi, AshwaniAssam and 1 others like this.
Hrvoje Jasak
Old   August 12, 2008, 05:17
Default Thanks Hrv for your help.
Maka Mohu
Old   August 27, 2008, 11:07
Default Hi Hrv do i need to checkme
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi Hrv
do i need to checkmesh before calculation,and creat the nonorth information file in the constant dictionary? to let the Non-orthogonal correction affect.
thanks
wayne
waynezw0618 is offline   Reply With Quote
Old   August 27, 2008, 11:33
Default No, just run it with a correct
Hrvoje Jasak
No, just run it with a corrected snGrad scheme.
Hrv
Hrvoje Jasak
Old   October 18, 2011, 06:14
Michael Buchmayr
MichiB is on a distinguished road
Hi!
I've been struggling to fully understand the laplacian schemes, and I think this may be the right thread to get some enlightment.
I'm still stuck at two points...
1)
I was able to follow the overrelaxed approach (as explained in Hrv's thesis) until this point:
gaussLaplacian.C:
00066 fvm.upper() = deltaCoeffs.internalField()*gammaMagSf.internalFie ld();
00067 fvm.negSumDiag();
Line 0066 fills the upper array of the fvMatrix with coefficients Gamma*[S^2/(d dot S)].
Tell me if I'm completely wrong, but I think this only holds true for scalar fields.
However, if you take the laplacian of a vector field (e.g. laplacian(nu,U)),
you should end up with a tensor dotted with the orthogonal part of the surface normal vector.
This should give off-diagonal contributions that should end up in the source term, right?
Where do they come into play? I couldn't figure it out yet.
2)
The second question that I have concerns the non-orthogonol correction:
00156 const surfaceVectorField Sn(mesh.Sf()/mesh.magSf());
00157
00158 const surfaceVectorField SfGamma(mesh.Sf() & gamma);
00159 const GeometricField<scalar, fvsPatchField, surfaceMesh> SfGammaSn
00160 (
00161 SfGamma & Sn
00162 );
00163 const surfaceVectorField SfGammaCorr(SfGamma - SfGammaSn*Sn);
00164
00165 tmp<fvMatrix<Type> > tfvm = fvmLaplacianUncorrected(SfGammaSn, vf);
00166 fvMatrix<Type>& fvm = tfvm();
00167
00168 tmp<GeometricField<Type, fvsPatchField, surfaceMesh> > tfaceFluxCorrection
00169 = gammaSnGradCorr(SfGammaCorr, vf);
00170
00171 if (this->tsnGradScheme_().corrected())
00172 {
00173 tfaceFluxCorrection() +=
00174 SfGammaSn*this->tsnGradScheme_().correction(vf);
00175 }
00176
00177 fvm.source() -= mesh.V()*fvc::div(tfaceFluxCorrection())().internalField();
At line 00163 the non-orthogonal part of the surface vector is calculated.
It should be gamma&(S - (d*S^2)/(d dot S)) (following Hrv's thesis).
However this doesn't correspond to the equation in line 00163.
I guess the programming is correct, since nobody ever complained in the forums,
but maybe someone knows the answer to my (probably stupid) questions.
fumiya and Niteck like this.
MichiB is offline   Reply With Quote
Old   October 25, 2011, 10:55
Michael Buchmayr
Hi!
For those who have problems understanding the laplacians in OpenFOAM, I found the answers to my questions in Ferzinger & Perić (1997) -> Chapter 8, Diffusive Fluxes
Hrv's PhD is a good lecture for laplacians in OpenFOAM, and F&P rounds the missing details up.
kaifu and fumiya like this.
About nonorthogonal correction in fvclaplacian 7islands OpenFOAM Running, Solving & CFD 4 December 9, 2012 22:54
When and how to apply nonOrthogonal correctors vvqf OpenFOAM Running, Solving & CFD 1 March 22, 2006 05:21
implementing FDM on nonorthogonal coordinate syste yfyap Main CFD Forum 3 June 13, 2001 16:51
on nonorthogonal boudary fitted coordinate yf yap Main CFD Forum 2 January 20, 2001 02:13
2nd derivative on nonorthogonal FV-mesh Thomas Wolfanger Main CFD Forum 1 June 29, 1999 11:00
