October 12, 2015, 06:05 |
Time step continuity error
Mike Lob
Rep Power: 10 |
Hi everyone!
This is my first time writing on this CFD forum. I'm trying to simulate flowfield around a VAWT, Darrieus type. But something is going wrong with time step continuity error. On the first time step it reaches a global value of e+36. I'm using AMI to simulate the rotation of the turbine. I've exported the mesh from Pointwise than merged 2 different part with mergeMeshes utility. Note that:
These are all the files i'm using in system Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleDyMFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.7853976; deltaT 0.0000109083; writeControl adjustableRunTime; writeInterval 0.0000109083; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep no; maxCo 1; // ************************************************************************* // functions ( forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches (pala1 pala1sopra pala1sotto pala2 pala2sopra pala2sotto pala3 pala3sopra pala3sotto); // pname p; // Uname U; rhoName rhoInf; log true; rhoInf 1.205; CofR (0 0 0); } ); Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default leastSquares; grad(p) leastSquares; grad(U) leastSquares; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; pcorr ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorr { solver GAMG; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration off; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; tolerance 0.02; relTol 0; } p { $pcorr; tolerance 1e-07; relTol 0.01; } pFinal { $p; tolerance 1e-07; relTol 0; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; } UFinal { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; } "(k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-7; relTol 0.1; } "(k|omega)Final" { $U; tolerance 1e-7; relTol 0; } cellMotionUx { solver PCG; preconditioner DIC; tolerance 1e-08; relTol 0; } } PIMPLE { correctPhi no; nOuterCorrectors 100; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { "(p|U|k|omega)" { tolerance 1e-2; relTol 0; } } } relaxationFactors { fields { } equations { "p.*" 0.3; "U.*" 0.7; "k.*" 0.8; "omega.*" 0.8; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 4; preservePatches (fisso fissosopra fissosotto volumelato volumesopra volumesotto); method scotch; distributed no; roots (); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 2 -2 0 0 0 0 ]; internalField uniform 0.375; boundaryField { inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.05; value $internalField; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } pala1 { type kqRWallFunction; value $internalField; } pala1sopra { type kqRWallFunction; value $internalField; } pala1sotto { type kqRWallFunction; value $internalField; } pala2 { type kqRWallFunction; value $internalField; } pala2sopra { type kqRWallFunction; value $internalField; } pala2sotto { type kqRWallFunction; value $internalField; } pala3 { type kqRWallFunction; value $internalField; } pala3sopra { type kqRWallFunction; value $internalField; } pala3sotto { type kqRWallFunction; value $internalField; } volumelato { type cyclicAMI; value $internalField; } volumesopra { type cyclicAMI; value $internalField; } volumesotto { type cyclicAMI; value $internalField; } cubodx { type zeroGradient; } cubosopra { type zeroGradient; } cubosotto { type zeroGradient; } cubosx { type zeroGradient; } fisso { type cyclicAMI; value $internalField; } fissosopra { type cyclicAMI; value $internalField; } fissosotto { type cyclicAMI; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 1118.034; boundaryField { cubodx { type zeroGradient; } cubosopra { type zeroGradient; } cubosotto { type zeroGradient; } cubosx { type zeroGradient; } inlet { type turbulentMixingLengthFrequencyInlet; mixingLength 0.001; value $internalField; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } fisso { type cyclicAMI; value $internalField; } fissosopra { type cyclicAMI; value $internalField; } fissosotto { type cyclicAMI; value $internalField; } volumelato { type cyclicAMI; value $internalField; } volumesopra { type cyclicAMI; value $internalField; } volumesotto { type cyclicAMI; value $internalField; } pala1 { type omegaWallFunction; value $internalField; } pala1sopra { type omegaWallFunction; value $internalField; } pala1sotto { type omegaWallFunction; value $internalField; } pala2 { type omegaWallFunction; value $internalField; } pala2sopra { type omegaWallFunction; value $internalField; } pala2sotto { type omegaWallFunction; value $internalField; } pala3 { type omegaWallFunction; value $internalField; } pala3sopra { type omegaWallFunction; value $internalField; } pala3sotto { type omegaWallFunction; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { cubodx { type freestream; freestreamValue $internalField; } cubosopra { type freestream; freestreamValue $internalField; } cubosotto { type freestream; freestreamValue $internalField; } cubosx { type freestream; freestreamValue $internalField; } fisso { type cyclicAMI; value $internalField; } fissosopra { type cyclicAMI; value $internalField; } fissosotto { type cyclicAMI; value $internalField; } inlet { type fixedValue; value uniform (10.0 0 0); } outlet { type zeroGradient; } pala1 { type fixedValue; value $internalField; } pala1sopra { type fixedValue; value $internalField; } pala1sotto { type fixedValue; value $internalField; } pala2 { type fixedValue; value $internalField; } pala2sopra { type fixedValue; value $internalField; } pala2sotto { type fixedValue; value $internalField; } pala3 { type fixedValue ; value $internalField; } pala3sopra { type fixedValue; value $internalField; } pala3sotto { type fixedValue; value $internalField; } volumelato { type cyclicAMI; value $internalField; } volumesopra { type cyclicAMI; value $internalField; } volumesotto { type cyclicAMI; value $internalField; } } // ************************************************************************* // |
Display Modes | |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
