November 8, 2011, 15:55 |
[LaunderGibsonRSTM-channel]
Dear Foamers,
I'm trying to simulate a channel with the LaunderGibsonRSTM model. I would like to resolve the walls without using wall functions, my first y+ is therefore 0.63. Unfortunately, my simulation blows up after a few time steps... I tried the solution provided by Sven in an other post regarding running the simulation with LaunderSharmaKE model and then use the RSTM... This is not working for me. Relevant dictionaries of my 0 directory, fvSchemes, fvSolution are provided below. initialisation epsilon: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 4.5e-07; boundaryField { bottomWall { // type epsilonWallFunction; // value uniform 1e-8; type fixedValue; value uniform 1e-16; //This is not 0!!! } topWall { // type epsilonWallFunction; // value uniform 1e-8; type fixedValue; value uniform 1e-16; //This is not 0!!! } sides1 { type cyclic; } sides2 { type cyclic; } inout1 { type cyclic; } inout2 { type cyclic; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 6.75e-05; boundaryField { bottomWall { type fixedValue; //zeroGradient; value uniform 1e-14; } topWall { type fixedValue; value uniform 1e-14; } sides1 { type cyclic;//empty; } sides2 { type cyclic;//empty; } inout1 { type cyclic; } inout2 { type cyclic; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volSymmTensorField; object R; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform (0 0 0 0 0 0); boundaryField { bottomWall { // type kqRWallFunction; type fixedValue; value uniform ( 0 0 0 0 0 0 ); } topWall { type fixedValue; // type kqRWallFunction; value uniform ( 0 0 0 0 0 0 ); } sides1 { type cyclic;//empty; } sides2 { type cyclic;//empty; } inout1 { type cyclic; } inout2 { type cyclic; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind;//Gauss limitedLinear 1.0; div(phi,k) Gauss upwind;//Gauss limitedLinear 1; div(phi,epsilon) Gauss upwind;//Gauss limitedLinear 1; div(phi,R) Gauss upwind;//Gauss linear; div(R) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear limited 0.333; //Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear limited 0.333; //Gauss upwind corrected; laplacian(DkEff,k) Gauss linear limited 0.333; //Gauss upwind corrected; laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333; //Gauss upwind corrected; laplacian(DREff,R) Gauss linear limited 0.333; //Gauss upwind corrected; //laplacian(DnuTildaEff,nuTilda) Gauss linear limited 0.333; //Gauss upwind corrected; //laplacian(nuEff,U) Gauss linear corrected; // laplacian((1|A(U)),p) Gauss linear corrected; //laplacian(DkEff,k) Gauss linear corrected; //laplacian(DepsilonEff,epsilon) Gauss linear corrected; //laplacian(DREff,R) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.1; } pFinal { solver PCG; preconditioner DIC; tolerance 1e-09; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } R { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } //relaxationFactors //{ // p 0.2; // U 0.7; // k 0.5; // epsilon 0.1; // R 0.5; // nuTilda 0.3; //} // ************************************************************************* // |
November 9, 2011, 09:04 |
issue solved. There exists no low Re formulation of the LaunderGibsonRSTM. Therefore wall functions have to be applied...
