FOAM FATAL ERROR for Different dimensions
Old   March 1, 2016, 13:32
Default FOAM FATAL ERROR for Different dimensions
Rupesh
rupesh_w is on a distinguished road
Hello Foamers,
I am unable to understand the following error related to Different Dimensions. I am using "sonicDymFoam" as my solver , and my dimensions for p and U are
p =[1 -1 -2 0 0 0 0]
U=[0 1 -1 0 0 0 0]
"Selected 0 cells for refinement out of 57432.
Selected 0 split points out of a possible 0.
solidBodyMotionFunctions::linearMotion::transforma tion(): Time = 0.0001 transformation: ((0 0.0001 0) (1 (0 0 0)))
--> FOAM FATAL ERROR:
Different dimensions for -=
dimensions : [1 0 -1 0 0 0 0] = [0 3 -1 0 0 0 0]
From function dimensionSet:perator-=(const dimensionSet&) const
in file dimensionSet/dimensionSet.C at line 199.
FOAM aborting"
Please let me know if more information is needed from my end to better understand this error.
Thanks in advance !!
rupesh_w is offline   Reply With Quote
Old   April 10, 2016, 17:23
Retired Super Moderator
Bruno Santos
Quick answer: I don't know if you've solved this issue or not, but please follow the steps given here: http://www.cfd-online.com/Forums/ope...-get-help.html
And please keep in mind that if you need people to stop and ask you for more details, that also takes time, time which could have been spent answering your question
For example, I will unlikely be able to look into your case in the next few weeks, given that you didn't provide enough details here
Old   April 27, 2016, 04:14
Rupesh
Dear Bruno,
Many thanks for sharing the info. I have posted my query/error in other thread on dynamicTopoFvMesh.
Regards,
Rupesh
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
