November 9, 2011, 13:30 |
Is there a way to enforce my timestep?
Shawn
Rep Power: 14 |
I'm using pimpleDyMFoam to simulate a vertical axis wind turbine with a stationary outer domain and a rotating inner domain using the ggi. I would like to be able to strictly enforce my timestep. I have tried to raise my maxCo to 100 (yes, I know the implications) but the deltaT used in the solution will never go higher than 0.000556 (my desired deltaT is 0.00278 which corresponds to 1 deg rotation at 60 RPM). The maxCo in the solution is ~7.33 so it never approaches 100.
Is there another parameter I should look at to get my deltaT to where I want? Convergence doesn's seem to be an issue at this Co/deltaT (7.3/5.6e-4) yet. Thanks, Shawn |
November 9, 2011, 13:40 |
Kent Wardle
Rep Power: 21 |
Is there a reason you cannot simply change system/controlDict such that:
deltaT 0.00278; adjustTimeStep no; This should give you a constant time step. -Kent |
November 10, 2011, 11:53 |
Shawn
Rep Power: 14 |
Wow...I guess I've been looking at this too long. That command is literally 2 lines above maxCo.
Thanks Kent! |
Restart 2-way FSI with different timestep? | Lance | CFX | 10 | April 17, 2013 00:37 |
How to interrupt unsteady calculation and carry on without timestep increase? | aleisia | FLUENT | 1 | March 18, 2011 23:02 |
Adequate timestep selection for multidomain problem | gerardosrez | CFX | 6 | November 28, 2010 17:50 |
interTrackFoam timestep | virginie_e | OpenFOAM Running, Solving & CFD | 4 | April 6, 2009 05:02 |
Timestep selection | Jindra Kosprdova | CFX | 9 | April 28, 2005 06:41 |
