Problem Setting floatTransfer Parameter
Old   November 16, 2011, 09:52
Default Problem Setting floatTransfer Parameter
Geoffrey Bell
GeoffreyJBell is on a distinguished road
I have a case in porousSimpleFoam that converges easily when run on a single processor as a serial job. However, when run in parallel using the follwing commands fails to converge:
runApplication blockMesh
runApplication setSet -batch createCanopy.setSet
runApplication setsToZones
runApplication decomposePar
runParallel redistributeMeshPar 4 -overwrite
runParallel renumberMesh 4 -overwrite
runParallel porousSimpleFoam 4
runApplication reconstructParMesh -constant
Since my understanding is that failure to converge can result from only single-precision communication between the processors, and that this transfer is controlled using the floatTransfer parameter, and possibly nProcsSimpleSum parameters in controlDict, I have made the following entries in controlDict:
floatTransfer 1;
nProcsSimpleSum 4;
Despite this however, the following is what appears at the top of the log file for porousSimpleFoam.
Note that floatTransfer is still 0, and nProcsSimpleSum is also still 0:
nProcs : 4
Slaves :
3
Pavilion.32246
Pavilion.32247
Pavilion.32248
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
I would like to be able to change these parameters for trouble-shooting purposes, and I am not sure what I am doing wrong here when trying to change them. I was wondering if anyone might know how I could do this?
Thanks,
Geoff Bell
GeoffreyJBell is offline   Reply With Quote
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 02:53
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 01:20
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Small problem with VR editor Song Phoenics 1 April 22, 2003 17:34
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 16:38
