November 28, 2011, 11:49 |
Tutorial "airFoil2D" yPlus value
Denis
Rep Power: 14 |
I have a question about the airFoil2D tutorial. I compute the given case and evaluated the y+ value with the yPlusRAS-function. So this is the solution: Code:
Patch 2 named wall y+ : min: 958.43 max: 13790.7 average: 8328.47 So is this a bug ?? Denis |
November 30, 2011, 05:42 |
Rep Power: 18 |
Hi Denis,
this isn't a bug I can assure you. The yPlus factor is a value which gives you an indication of the resolution of the boundary layer. ( yPlus = (u * y) / nu ) If you want to make a simulation without further approximations this value should be 1. However this results in lots of cells so some guys had the idea of the usage of wall functions. This allows you to increase this value up to 300 and the results may still look like a good representation of the reality (for engineers this is usually enough). Since you can then use less cells also the calculation time decreases which is quite handy. Which brings us to the tutorials: They are made to show you the general principle of a solver/feature so they usually use a coarse mesh which must not necessarily full fill all the requirements one has to a mesh, so quality or resolution factors might exceed the values which you would use for a real computation where you rely on the results. I hope I explained everything well enough regards |
Display Modes | |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 04:45 |
Who stole my Yplus? | Chebeba | CFX | 4 | March 23, 2006 04:18 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 04:43 |
