July 27, 2017, 05:36 |
pressure in buoyantBoussinesqSimpleFoam
Hugo
Rep Power: 8 |
Hello everyone,
I use buoyantBoussinesqSimpleFoam solver. My case is close to the windaroundBuildings tutorial. Each parameter seems to work fine, but when I want to read the pressure, I select p and the scale starts from approximately -712 until 707. So I can read that the average pressure around the buildings is about -360. The units are supposed to be in m²/s². So to have the real pressure in Pascal, I am supposed to multiply it by rho. But here rho = 1.2 kg/m^3 ~ 1 kg/m^3, so it should be a pressure of -360 Pa which is completely wrong ! PS: for the same time, when I read p_rgh, the scale starts from -100 until 17... and the average pressure around buildings seem to be close to 0.... I used simflow for this case. In initial conditions: p-rho*g*h=0. In boudary conditions: for the inlet: p-rho*g*h is zero gradient for the outel: p-rho*g*h is fixed value =0 |
July 27, 2017, 15:30 |
Have you set internal field for p and p_rgh equal to 0 or 10e5 Pa?
Sent from my ASUS_X008D using CFD Online Forum mobile app |
August 8, 2017, 06:38 |
#3 | |
Hugo
Rep Power: 8 |
EDIT: I found in the folders that p and p_rgh are both defined as: internalField uniform 0.0 Here is some screenshots: for p: for p_rgh: |
August 8, 2017, 08:10 |
#4 | |
Hugo
Rep Power: 8 |
internalField unfinorm 0.0 Here some screenshots: for p: for p_rgh: |
June 13, 2022, 11:50 |
Mahmoud
Rep Power: 5 |
Dear Foamers,
It’s been a while that I’ve had the same problem in setting the correct BC for similar problems. Here is the review of how I solved this issue: Problem: steady state open channel flow simulation. In this scenario, normally the simpleFoam is employed. The BCs are given by: BCs: inlet, outlet, wall, topWall U: inlet { type fixedValue; value uniform (0 0.1589 0); } outlet { type zeroGradient; } wall { type noSlip; } atmosphere { type slip; } p: atmosphere { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } wall { type fixedFluxPressure; //remember that we cannot use Drichlet and Neuman BC at the same time value uniform 0; } As one can see, selecting fixedValue BC for the outlet pressure is physically incorrect even though one can get result. To resolve this issue, I decided to use the hydrostatic pressure as the outlet BC for the pressure. To this end, one need to either define gravity in the governing equation or else use a steady state solver that has gravity in the equations. I went for the second approach. The only available solver for incompressible fluids that has this feature is buoyantBoussinesqSimpleFoam. When this solver is selected, the BCs needs to be defined for the U, p, and p_rgh. Generally, p_rgh=p-rho*g*h. I have searched a lot and finally could find the correct way of setting BC for the foregoing parameters. U: inlet { type fixedValue; value uniform (0 0.1589 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); inletValue uniform (0 0 0); } wall { type noSlip; } atmosphere { type slip; } P: atmosphere { type zeroGradient; } inlet { type zeroGradient; } outlet { type calculated; value $internalField; } wall { type zeroGradient; } P_rgh inlet { type fixedFluxPressure; } outlet { type fixedValue; value uniform 0; } wall { type fixedFluxPressure; } atmosphere { type fixedFluxPressure; } let me know if it is not clear. Keep Foaming |
Display Modes | |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 05:43 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
