FSI - dynamic Meshing
Old   January 12, 2012, 05:37
Default FSI - dynamic Meshing
Dimitris
dskoutel is on a distinguished road
Hello everyone
I want to share a problem i m facing with openFoam dynamic
meshing while trying to perform FSI simulations.
I m importing new boundary conditions- displacements/velocities from an external FEM solver and put them to the appropriate pointDisplacement/pointMotionU file, depending on the solver i choose. Curiously after the mesh.update() is executed i get a mesh that does not quite follow the new boundary conditions...(?)
I tried with simpler deformations and it turns out that it would only work whenever the boundary condition at the specific moving patch is uniform.
Did anybody have such a problem before or has any advice for me?
dskoutel is offline   Reply With Quote
Old   January 12, 2012, 09:11
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
What did you mean by saying "uniform"?
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   January 12, 2012, 09:50
Dimitris
by uniform i mean sth like:
solidBody
type fixedValue;
value uniform (0.1 0.1 0);
Problem starts when the boundary condition in non uniform so instead i input a list of vectors.
Old   January 12, 2012, 09:54
lakeat's Avatar
Daniel WEI (老魏)
Hmm.., why did you use fixedValue patch, and not using the sixDoF... patch?
Daniel WEI
Beijing, China
Email
Old   January 12, 2012, 10:02
Dimitris
sixDoFRigidBodyDisplacement is not availiable in version 2.0 i think. I used fixedValue following the icoFsiFoam way.
Old   January 12, 2012, 10:10
lakeat's Avatar
Daniel WEI (老魏)
You mean,
OpenFOAM-2.x/src/postProcessing/functionObjects/forces/pointPatchFields/derived
Daniel WEI
Beijing, China
Email
Old   January 12, 2012, 10:22
Dimitris
no i mean
--> FOAM FATAL IO ERROR:
Unknown patchField type sixDoFRigidBodyDisplacement for patch type patch
Valid patchField types are :
24
angularOscillatingDisplacement
angularOscillatingVelocity
calculated
cyclic
cyclicSlip
empty
fixedNormalSlip
fixedValue
mixed
nonuniformTransformCyclic
oscillatingDisplacement
oscillatingVelocity
processor
processorCyclic
slip
surfaceDisplacement
surfaceSlipDisplacement
symmetryPlane
timeVaryingUniformFixedValue
uniformFixedValue
value
waveDisplacement
wedge
zeroGradient
Old   January 12, 2012, 10:23
lakeat's Avatar
Daniel WEI (老魏)
But surely you can load the .so file to add the new patches.
Daniel WEI
Beijing, China
Email
Old   January 12, 2012, 11:03
Dimitris
hmm ok loaded genericPatchFields library but i get some runtime errors...guess i need to check some stuff first. do u have any fsi solver in mind that actually uses this 6dof patch? i only saw it on pimpleDyMfoam but it doesnt seem to help much...
thanks for your help !
Old   January 13, 2012, 13:06
lakeat's Avatar
Daniel WEI (老魏)
pimpleDyMFoam can do the job. And sicDoF b.c patch is in another .so library, load the correct one.
Daniel WEI
Beijing, China
Email
dynamic meshing, fluid-structure, fsi, mesh deformation, mesh displacement
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 11:01
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 19:26
Dynamic Meshing with Flow 3D M_Agni FLOW-3D 1 June 13, 2010 18:20
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
