April 1, 2008, 05:23 |
Hi..
I'm trying to modify t
Niels Nielsen
Rep Power: 27 |
Hi..
I'm trying to modify the reactingFoam solver to be steady state. I've had some success and have been able to create a solver which actually works (bear in mind i have only used OpenFOAM + C++ for 2 months :-)).. The problem is now that when the solver goes from itt. 1 to 2 the chemistry part of the solver crashes with following output. If anyone has an idea to where the stuff breaks please be free to post. Or if more info is needed. ------------%%%%%%%%%%%%------------------- Creating turbulence model Selecting turbulence model kEpsilon Creating field DpDt Constructing chemical mechanism Selecting ODE solver SIBS chemistryModel::chemistryModel: Number of species = 9 and reactions = 5 Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.27053e-07, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.53356e-07, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.93888e-07, No Iterations 4 DICPCG: Solving for p, Initial residual = 0.999999, Final residual = 9.29203e-10, No Iterations 330 time step continuity errors : sum local = 4.59095e-07, global = -2.06926e-10, cumulative = -2.06926e-10 rho max/min : 0.994073 0.757904 Solving chemistry diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 1, Final residual = 6.83189e-07, No Iterations 79 DILUPBiCG: Solving for O2, Initial residual = 1, Final residual = 8.5065e-07, No Iterations 77 DILUPBiCG: Solving for CO2, Initial residual = 1, Final residual = 6.01839e-07, No Iterations 45 DILUPBiCG: Solving for H2O, Initial residual = 1, Final residual = 6.01839e-07, No Iterations 45 DILUPBiCG: Solving for CO, Initial residual = 1, Final residual = 6.69834e-07, No Iterations 89 DILUPBiCG: Solving for O, Initial residual = 2.27305e-15, Final residual = 2.27305e-15, No Iterations 0 DILUPBiCG: Solving for OH, Initial residual = 4.95287e-22, Final residual = 4.95287e-22, No Iterations 0 DILUPBiCG: Solving for H, Initial residual = 3.95626e-21, Final residual = 3.95626e-21, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 8.46321e-07, No Iterations 151 DILUPBiCG: Solving for epsilon, Initial residual = 0.981056, Final residual = 1.65846e-07, No Iterations 4 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 9.46134e-07, No Iterations 4 ExecutionTime = 43.6 s ClockTime = 49 s Time = 2 DILUPBiCG: Solving for Ux, Initial residual = 0.14041, Final residual = 3.81936e-08, No Iterations 6 DILUPBiCG: Solving for Uy, Initial residual = 0.117192, Final residual = 1.78371e-07, No Iterations 5 DILUPBiCG: Solving for Uz, Initial residual = 0.12593, Final residual = 8.13593e-07, No Iterations 4 DICPCG: Solving for p, Initial residual = 0.676268, Final residual = 8.91297e-10, No Iterations 345 time step continuity errors : sum local = 4.24033e-07, global = -6.36642e-10, cumulative = -8.43568e-10 rho max/min : 0.994533 0.266745 Solving chemistry #0 Foam::error::printStack(Foam:stream&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 pow in "/lib/tls/libm.so.6" #4 Foam::chemistryModel::omega(Foam::Reaction<foam::s utherlandtransport<foam::speci ethermo<foam::janafthermo<foam::perfectgas> > > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libchemistryModel.so" #5 Foam::chemistryModel::omega(Foam::Field<double> const&, double, double) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libchemistryModel.so" #6 Foam::chemistryModel::derivatives(double, Foam::Field<double> const&, Foam::Field<double>&) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libchemistryModel.so" #7 Foam::SIBS::SIMPR(Foam:DE const&, double, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Matrix<double> const&, double, int, Foam::Field<double>&) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libODE.so" #8 Foam::SIBS::solve(Foam:DE const&, double&, Foam::Field<double>&, Foam::Field<double>&, double, Foam::Field<double> const&, double, double&, double&) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libODE.so" #9 Foam:DESolver::solve(Foam:DE const&, double, double, Foam::Field<double>&, double, double&) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libODE.so" #10 Foam::ode::solve(Foam::Field<double>&, double, double, double, double) const in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libchemistryModel.so" #11 Foam::chemistryModel::solve(double, double) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libchemistryModel.so" #12 Uninterpreted: .././reactingFoam-new [0x805d12e] #13 __libc_start_main in "/lib/tls/libc.so.6" #14 __gxx_personality_v0 Floating point exception
Linnemann PS. I do not do personal support, so please post in the forums. |
April 1, 2008, 06:20 |
Okay partially found the answe
Niels Nielsen
Rep Power: 27 |
Okay partially found the answer to my problem..
The chemistry solver is not steady state and depends on deltaT somehow, so setting a small time step in the dictionary will allow the calculation to continue.. So now to a new question. Any guidelines howto make the chemistry solver steady state,, any hints?
April 2, 2008, 02:10 |
Hello Niels,
there is work
Markus Rehm
Rep Power: 17 |
Hello Niels,
there is work going on towards a EDC-based steady state solver. In principle you have tu use under relaxation together with coupling of chemical time scales to the time scales of the flow. Maybe some limits for temperature differences need to be added as well. I will tell you if I reached the goal. I hope I can achieve something until the Milan Workshop. Regards Markus. |
April 23, 2008, 04:08 |
Hi Again,
Could Anyone give
Christian Andersen
Rep Power: 17 |
Hi Again,
Could Anyone give som input to how to implement a IF-sentence in OpenFOAM? For each cell I need to determine the minimum of: omega_fu = CH4 omega_ox = O2/s omega = min(omega_fu, omega_ox) How do I get OpenFOAM to select the minimum reaction rate? I've tried with an if sentence: /******************************************/ omega_fu = C_R*rho*CH4*epsilon/k; omega_ox = C_R*rho*O2/st*epsilon/k; omega_pr = C_RR*rho*(1-CO2-H2O)/(1+st)*epsilon/k; if (omega_fu > omega_ox) { omega = omega_ox; } if (omega > omega_pr ) { omega = omega_pr; } /************************************/ Any help/comments will be appreciated! Best Christian Andersen |
April 24, 2008, 08:10 |
I figured it out by reading th
Christian Andersen
Rep Power: 17 |
I figured it out by reading this thread:
http://www.cfd-online.com/cgi-bin/Op...pc=1&post=5191 If others have same problem, I'd be happy to send my code as an example. Best Christian |
June 11, 2008, 10:04 |
To whom it may concern.
I'v
Christian Andersen
Rep Power: 17 |
I've been working with OpenFOAM for the last 4 months and I've come this far: I have implementet the mixing rate limited reaction model of Eddy Break-Up model, Eddy Dissipation concept and the mixturefraction model. However, my coding is not object oriented nor optimal. The thermodynamic coupling to the flow properties is still missing. Comparison with Fluent for disabled energy-equation showed good results. I would like to make this work available to others, that can use it to get started with OpenFOAM. Can someone tell me how I can upload/present this model? Best Christian Andersen |
June 12, 2008, 00:12 |
Christian Andersen,
I am wo
Ratna Kishore
Christian Andersen,
I am working on laminar flames for H2-CO mixtures. does your code can be used for that. In case I can have it for that purpose. I am at present using Fluent but it is giving some trouble. my email id ratnavk@gmail.com |
June 27, 2008, 02:58 |
Dear Christian,
look on the
Stefan Radl
Rep Power: 18 |
Dear Christian,
look on the help panel under Documentation/Formatting and then search for attachments. There you'll find hints how to post the solver here. I'm very much interested in your solver for my research on reactions in turbulent flows in bubble swarms. Maybe you can send it to me under stefan <dot> radl <ad> tugraz <dot> at |
June 14, 2009, 02:57 |
#9 |
Sanjib Das Sharma
Rep Power: 16 |
Hi Christian,
Very nice of you to make your code available. I have downloaded your document from the internet and have gone through it. Although I am an experienced user of FLUENT, but I have started OpenFOAM only few days back. However, the project I am working is quite daunting and very much similar to your project. I want to do the following: 1) Implement multi-species, multiple reaction turbulent reactive flow 2) Turbulent-chemistry interaction is through Eddy break-up model 3) The solver is steady state 4) Density change due to liquid-to-vapor flashing 5) Inclusion of latent heat of vaporization 6) Phase-partitioning between vapor and liquid This project has already been developed in FLUENT and I am trying to migrate it in OpenFOAM. You can send the file to sanjibdsharma@gmail.com and tell me how do I run the code in OpenFOAM. I might also need your help as I move deeper into the project. Thanks and regards, Sanjib |
September 21, 2010, 06:05 |
#10 |
Gabriel D
Rep Power: 15 |
hello,
i am also using reactingFoam but for a supersonic combustion. In fact it is a steady state problem, but reactingFoam can only be used transient. it would be great, if if someone has a modification for steady state problems. my email is: gabrieldilmac@googlemail.com thank u best regards Gabriel |
November 24, 2010, 10:16 |
#11 |
Antonio Liggieri
Rep Power: 14 |
Hello Niels,
You mentioned to have modified reactingFoam from tranisient to steady sate. I'm about to do the same and was looking for information in the net. Is it a big deal. All the best, Tony |
January 21, 2014, 11:36 |
#12 |
Faraj
Rep Power: 16 |
Hi, 2 years passed...any progress? would be very thankfull if you send the solver to me, too.
faraj.khalikov@gmail.com Thanks you in advance. |
June 5, 2014, 11:14 |
reactingFoam to steadyState
#13 |
James
Rep Power: 12 |
Hi guys,
Just wondering if you have been successful in creating a steadyState version of reactingFoam? Thanks, James |
April 7, 2015, 12:59 |
steady state reactingFoam
#14 |
Ali Kadar
Rep Power: 11 |
Hi, it has been long since this thread started, its almost dead .
Has anybody been successful in creating a steady state solver based on the EDC concept, similar to the reactingFoam ? Currently it is based on the PIMPLE algorithm and is limited by a low courant no (maxCo<1). However it is possible to accelerate it using ideas from SIMPLE(more outer correctors and under-relaxation). http://openfoamwiki.net/index.php/Op...hm_in_OpenFOAM However is it possible to completely replace PIMPLE with SIMPLE and if so what happens to the chemistry time scale and how do we deal with it? How does it work in Fluent. What is the idea ? Do we really need to care about the chemistry time scale when considering "mixed=burnt" assumption. I suppose not!. But I am not a chemisrty guy and I am not clear about this ? Please if someone can illustrate. It will be very helpful.
A good solution is one which does justice to the inner nature of the problem- Cornelius Lanczos in a letter to Albert Einstein on March 9, 1947 |
April 7, 2015, 13:10 |
#15 |
Ali Kadar
Rep Power: 11 |
Hey I just found this new thread and some good human beings are contributing to a steady state reactingFoam. Cheers to there work.!
modify reactingFoam in order to make it a steady state solver http://www.cfd-online.com/Forums/ope...te-solver.html
Steady state | Ruben | Main CFD Forum | 43 | May 7, 2011 03:32 |
Steady State DPM | K. Jagus | FLUENT | 7 | June 24, 2005 17:10 |
Steady state at vof!! | Heydari | FLUENT | 6 | December 22, 2002 07:27 |
Steady state in VOF | CFD Newbie | FLUENT | 4 | December 18, 2002 16:11 |
VOF steady state? | CFD Newbie | Main CFD Forum | 3 | December 16, 2002 00:23 |
