June 15, 2016, 04:45 |
pimpleFoam not writing fields
Max Vorstadt
Rep Power: 9 |
Hi! I'm using pimpleFoam and sadly after performing more than 2000 iterations I wanted to reconstruct the case by reconstructPar -latestTime but the folder created did not have any file containing the fields that I want to represent in paraView. I've checked the controlDict file just in case but nothing seems wrong or different.
I'm attaching the controlDict and the pimpleFoam logfile just in case they are needed. Inside the resulting time folder the only document available to represent on paraview is the file "desFields", according to a function described in the controlDict. Thanks in advance! Last edited by jet_engine; June 15, 2016 at 09:41. |
November 20, 2018, 07:14 |
#2 | |
navid toussi
Rep Power: 10 |
in your control dict you set writeInterval to 250 which means that your simulation needs to reach to 250 second inorder to write a binary file, which means a lot. so i suggest you to decrease it to 1 and wait for your simulation to reach 1 second and then check whether you have any binary file or not. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
