High speed flow with Launder-Sharma-k-epsilon-Model
Old   February 6, 2012, 05:04
Default High speed flow with Launder-Sharma-k-epsilon-Model
Sebastian Saegeler
sebastian is on a distinguished road
Dear All,
I need to run a compressible high speed nozzle flow in OF on a low-Re mesh (y+<1).
So far I did my calculations with the kOmegaSST turbulence model and it worked quite nice.
Now I have to use the k-Epsilon turbulence model on the same mesh.
The only low-Re k-epsilon turbulence for a compressible case available in OF is the one by Launder and Sharma.
I compared the code of the LaunderSharmaKE with the standard kEpsilon model and found some differences as additional source-terms as well as some turbulent Reynolds-number functions.
So I have some questions, hoping anybody can answer these:
  1. Is it okay to use the Launder-Sharma k-e-model for such a case?
  2. How does this turbulence model behave in regions far away from the wall? Does it differ from the standard k-epsilon model or are thes modifications only due to near wall regions?
  3. As my y+-values are everywhere below 1.0, I can not use wall functions. Any other suggestions to solve this flow problem with a k-epsilon model?
Thanks in advance!
Sebastian
sebastian is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... Ruonin Main CFD Forum 17 February 17, 2014 09:52
Low Speed flow in Micro Gravity; what model? Brice FLUENT 0 June 13, 2007 10:30
High Speed Supersonic Flow Through Pipe Benjamin Zachariah Main CFD Forum 0 April 19, 2007 10:16
Segregated or Coupled? High Speed Flow Mixing. Mazhar Azim FLUENT 2 March 29, 2007 10:53
