How to simulate flows around ships with GGI
Old   June 2, 2012, 13:30
Default How to simulate flows around ships with GGI
slint is on a distinguished road
I want to simulate flows around a ship for several wind directions with OpenFOAM. So I have to rotate the ship or the domain for that job. We did that in CFX with two independent meshes (the ship is placed in a cylinder, the domain rotates around the cylinder) and the GGI Interface. I know that GGI is also available in OpenFOAM, but I don't know how to implement this function.
Is there anybody, who can give me some basic information about the implementation of GGI interface? I found some tutorials about turbomachinery, but this was not useful...
I appreciate every good advice, thanks.
slint is offline   Reply With Quote
Old   June 5, 2012, 10:21
maHein is on a distinguished road
hi slint,
you could start with the ERCOFTAC centrifugal pump test cases. In one case, the inner mesh is rotating while the outer is fixed.
If you are using OpenFOAM 2.1, you could start with the propeller tutorial (incompressible/pimpleDyMFoam/propeller I think). Again, one rotating inner mesh and a fixed outer mesh coupled by an interface (cyclicAMI - similar to GGI in OpenFOAM 1.6ext).
martin
maHein is offline   Reply With Quote
Old   June 13, 2012, 12:59
hi martin,
thanks for your advice. After some trail and error, AMI seems to work well
Robert
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:07
alternative method for ggi wWieWalter OpenFOAM 1 September 20, 2011 08:18
Rotating cylinder with GGI lbeaudet OpenFOAM Running, Solving & CFD 4 July 6, 2009 02:13
plastic flows carno Siemens 2 November 13, 2003 12:31
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
