confused about components of totForce in forces function object |
July 6, 2013, 22:00 |
#1 | |
shiv
Rep Power: 13 |
Hi all,
I am using libforces.so to calculate the darg and lift, can someone please tell me what are these forces_[], OpenFOAM-2.2.x /src /postProcessing /functionObjects /forces /forceCoeffs /forceCoeffs.C Quote:
July 7, 2013, 02:23 |
Fumiya Nozaki
Rep Power: 18 |
These are the pressure force, viscosity force, and porous force, respectively. You might want to take a look at the forces.H and forces.C:
Hope this helps, Fumiya |
July 7, 2013, 02:52 |
shiv
Rep Power: 13 |
thanks Fumiya, I get it now.
drag coefficient, force coefficients, lift and drag |
Display Modes | |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
