Problem running simpleFoam with kOmegaSST turbulence model
Like Tree1Likes
  • 1 Post By tomf
Old   November 1, 2012, 07:02
Default Problem running simpleFoam with kOmegaSST turbulence model
MB
matzbanni is on a distinguished road
I'm trying to run a channel-case (4m^2) with a smaller cross-section (0.05m^2) in between. My boundary-conditions are:
inlet_velocity (0.3 0 0)
inlet_pressure zeroGradient
inlet_k uniform 2e-04
inlet_omega uniform 0.2
inlet_nut uniform 0
outlet_velocity zeroGradient
outlet_pressure uniform 0
outlet_k zeroGradient
outlet_omega zeroGradient
outlet_nut uniform 0
wall_velocity (0 0 0)
wall_pressure zeroGradient
wall_k kqRWallFunction uniform 2e-04
wall_omega omegaWallFunction uniform 0.2
wall_nut nutkWallFunction uniform 0
fvSchemes:
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div(phi,k)      Gauss linear;
    div(phi,omega)  Gauss linear;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
and finally fvSolution:
solvers
    p
        solver           GAMG;
        tolerance        1e-06;
        relTol           0.01;
		smoother	 DICGaussSeidel;
        cacheAgglomeration on;
		agglomerator	 faceAreaPair;
        nCellsInCoarsestLevel 50;
        mergeLevels      1;
    U
        solver           PBiCG;
		preconditioner	 DILU;
		tolerance        1e-05;
        relTol           0.1;
    k
        solver           PBiCG;
        tolerance        1e-05;
        relTol           0.1;
    omega
        solver           PBiCG;
		tolerance        1e-05;
        relTol           0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
		epsilon			0.7;
        omega           0.7;
		nuTilda			0.7;
		R				0.7;
The problem is that the calculation diverges with bounding k and omega. Any suggestions?
matzbanni is offline   Reply With Quote
Old   November 1, 2012, 08:23
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
can you post images of the mesh? have you tried to visualize where the k and omega rises to high values?
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   November 1, 2012, 09:15
MB
there is no defined location where the k and omega values reach the high values. it depends on the timestep... attached you can find two screenshots of a slice through the fluid domain.
Old   November 1, 2012, 17:15
sail's Avatar
Vieri Abolaffio
mmm the mesh looks good from here,
are the layers correctly added even in the corners?
maybe increasing the number of nonOrtogonalCorrectors in the simple loop?
if the issue arises in the early timesteps you might want to try to increase the value of the initial omega internal field to artificially stabilize the solution.
this is what comes to mind right now...
Old   November 2, 2012, 17:31
MB
tried to solve it without turbulence, but also no convergence. I have no idea what the problem is...
Old   November 3, 2012, 06:45
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Just looking at your fvSchemes, try changing:
divSchemes
    default         none;
to:
divSchemes
    default         none;
    div(phi,U)      Gauss GammaV 0.5;
    div(phi,k)      Gauss Gamma 0.5;
    div(phi,omega)  Gauss Gamma 0.5;
You are now introducing some filtering, because I doubt that you have the required resolution (Cell Reynolds number <2) for pure central differencing (linear scheme). Or maybe look at limitedLinear instead of Gamma.
You may even want to use upwind for the turbulence variables if that is needed for convergence, to my experience the end result is not affected significantly.
Especially if you have a lot of nonOrthogonality this may help:
laplacianSchemes
    default         Gauss linear limited 0.333;
Regards,
Tom
blake likes this.
tomf is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Turbulence model for mixing problem??? nileshjrane Main CFD Forum 7 September 14, 2010 04:57
Turbulence model for mixing problem nileshjrane OpenFOAM Running, Solving & CFD 1 September 7, 2010 17:48
Implementing and running a new turbulence model svens OpenFOAM 3 August 21, 2009 02:59
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
