Ggi Question
Like Tree1Likes
  • 1 Post By JulytoNovember
Old   March 19, 2012, 12:09
Default Ggi Question
Jason Eason
JulytoNovember is on a distinguished road
I want to run a case with pimpleDyMFoam on OpenFOAM-1.6-ext, I have a 3D rotor. I've studied icoDyMFoam, for more background on ggi. My rotor is inside of my ggi, my checkMesh indicates there are problems with my ggi. BlockMesh is how I created my rotor and ggi. I created my ggi with 4 blocks, and its 1D.
1. Can the ggi be the outermost mesh? Or does it have to be housed within a mesh?
2. Does the ggi have to be implemented with the inside and outside using a different number of blocks as with the icoDyMFoam tutorial?
If someone could post an example for just a ggi mesh it would help immensely. Thank You.
For anyone who has the same questions, I think I've found all the answers to my own questions.
1. I 'm not 100% about does it have to be the outermost, for my case I created my ggi from an outer mesh. To set the outsideSlider faces.
2. I've created my ggi using the same number of blocks for the insideSlider and the outsideSlider. The 2 sliders can't contain the same vertices, just make 2 vertices that occupy the same point. Assign 1 to the insideSlider and the other to the outsideSlider. The points that occupy the same space should never connect to one another. Essentially making the slider 2D, while working in 3D.
I hope this helps someone .
Gwenael likes this.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
ggi
ggi and "uncovered faces found" aqua OpenFOAM Running, Solving & CFD 1 October 29, 2019 00:41
GGI together with topological changes... kalle OpenFOAM Running, Solving & CFD 6 May 7, 2012 13:50
GGI in OpenFOAM-1.5-dev philippose OpenFOAM Running, Solving & CFD 14 November 13, 2011 14:55
GGI in Parallel error renyun0511 OpenFOAM Running, Solving & CFD 1 November 9, 2011 21:56
questions about GGI interface overlap adam2008 CFX 3 March 20, 2011 21:08
