April 2, 2012, 05:06 |
Axi - symmetric flow in OpenFOAM
ivan
Rep Power: 16 |
I started to solve axi - symmetric flow in OpenFOAM. There was problem with continuity. Where is larger area, there should be smaller speed but the problem can be seen from figures. At the end of the domain is higher speed than at the start of the domain. At the inlet is smaller area than at the outlet. The boundary conditions were : inlet U, p...zerrogradient outlet p...0, U zerrogradient wall ... wedge boundary condition at the side of the domain I don't know if I used correctly the wedge boundary condition. Thank you very much for your answer, Ivan. |
[Other] OpenFoam Flow over a Circular Cylinder | WolfgangS. | OpenFOAM Meshing & Mesh Conversion | 12 | March 3, 2014 10:53 |
nano fluif flow in openfoam | anijdon | OpenFOAM | 0 | February 18, 2011 16:22 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
Flow about symmetric shape is not symmetric | PetrK | CFX | 7 | August 23, 2006 11:54 |
symmetric flow around fuselage | Christoph | FLUENT | 0 | November 3, 2005 05:50 |
