time step huge continuity errors, please take a look at my BCs |
April 15, 2012, 12:07 |
Mihai Pruna
I'm using simplefoam trying to solve a simple case of pressure driven flow through a duct shaped like an s.
i got some results when i set the inlet velocity to 0, but i understand that is not the right way to do it and that it should be set as i set it below,which crashes. p: FoamFile { version 2.0; format ascii; class volScalarField; object p; } dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.000000; boundaryField { inletXmin { type freestreamPressure; freestreamValue 0.000000; } outletXmax { type fixedValue; value $internalField; } bottomYmin { type freestreamPressure; freestreamValue 0.000000; } topYmax { type freestreamPressure; freestreamValue 0.000000; } leftZmin { type symmetryPlane; } rightZmax { type freestreamPressure; freestreamValue 0.000000; } vol1face1 { type zeroGradient; } vol1face2 { type zeroGradient; } vol2face1 { type fixedValue; value uniform 100000; } vol3face1 { type fixedValue; value $internalField; } } u: FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } #include "include/initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.000000 0.000000 0.000000); boundaryField { inletXmin { type freestream; freestreamValue uniform (0.000000 0.000000 0.000000); } outletXmax { type inletOutlet; inletValue $internalField; value $internalField; } bottomYmin { type freestream; freestreamValue uniform (0.000000 0.000000 0.000000); } topYmax { type freestream; freestreamValue uniform (0.000000 0.000000 0.000000); } rightZmax { type freestream; freestreamValue uniform (0.000000 0.000000 0.000000); } leftZmin { type symmetryPlane; } vol1face1 { type fixedValue; value uniform (0 0 0); } vol1face2 { type fixedValue; value uniform (0 0 0); } vol2face1 { type pressureInletVelocity; value uniform (0 0 0); } vol3face1 { type inletOutlet; inletValue $internalField; value $internalField; } } error: #0 Foam::error:rintStack(Foam::Ostream&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 void Foam::vtkSurfaceWriter::writeData<double>(Foam::Os tream&, Foam::Field<double> const&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #4 void Foam::vtkSurfaceWriter::writeTemplate<double>(Foam ::fileName const&, Foam::fileName const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::face> const&, Foam::word const&, Foam::Field<double> const&, bool, bool) const in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #5 void Foam::sampledSurfaces::sampleAndWrite<double>(Foam ::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #6 void Foam::sampledSurfaces::sampleAndWrite<double>(Foam ::sampledSurfaces::fieldGroup<double>&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #7 Foam::sampledSurfaces::write() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #8 Foam::OutputFilterFunctionObject<Foam::sampledSurf aces>::execute(bool) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so" #9 Foam::functionObjectList::execute(bool) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #10 Foam::Time::run() const in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #11 Foam::Time::loop() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #12 Foam::simpleControl::loop() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #13 in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/simpleFoam" #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #15 in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception
Mihai Pruna's Bio |
April 15, 2012, 19:15 |
Mihai Pruna
Ok, with a finer mesh it's better, no crashes
Time = 10 smoothSolver: Solving for Ux, Initial residual = 0.007497, Final residual = 0.000191026, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00780401, Final residual = 0.000205816, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.00731843, Final residual = 0.000192019, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0264498, Final residual = 0.0025477, No Iterations 2 time step continuity errors : sum local = 4868.62, global = -409.19, cumulative = -31928.9 smoothSolver: Solving for omega, Initial residual = 0.0062248, Final residual = 0.000119997, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.014408, Final residual = 0.00032159, No Iterations 2 ExecutionTime = 2315.79 s ClockTime = 2320 s
Mihai Pruna's Bio |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 16:24 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
