Which equations are solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam? |
March 16, 2015, 19:04 |
Guilherme
Rep Power: 12 |
Is there any documentation describing the system of equations solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam? Since I am relatively new to OpenFoam, I am not quite sure about the meaning of the equations I found in the source code.
Thanks in advance. |
April 19, 2015, 12:13 |
Hassan Kassem
Rep Power: 17 |
rhoCentralFoam was discussed before in this forum, you can search for it.
The original paper for rhoCentralFoam; http://onlinelibrary.wiley.com/doi/1....2069/abstract and you can check this paper as well; http://www.cimec.org.ar/ojs/index.ph...File/4231/4157 If you are going to use rhoCentralFoam make sure that you are using the latest version of OF because the solver was updated recently. Bw, Hassan |
