July 3, 2020, 20:48 |
chtMultiRegionFoam transient case issue
Rep Power: 5 |
update--- the time step was too big in the setting. Still not sure how fluent was able to get the right value with the same time step, but Openfoam needs a much smaller (6 magnitudes smaller) time step so that the diffusion number is reasonably small to get accurate results.
All, I am new to OpenFOAM and currently solving a heat transfer problem with two different materials. Here is the model setup: I have a quarter of a sphere with a core and a shell. the initial Temperature is uniform everywhere, and the surface of the sphere is losing heat through convection with constant h. To verify the basic model setup, I set both core and shell to be the same material property, and the Biot number is small enough that the Temperature variation with time should be the same as the results from Lumped Capacitance Method. However, the results from Openfoam case is different from the LCM and Fluent model. I attached a plot to show the difference. Since I converted the mesh from Fluent, and the Fluent case ran just file, I am guessing this is not a meshing issue. I have checked the material properties many times and they are the same as what I used for LCM and fluent. Any advice would be appreciated! Here is the boundary condition on the surface of the shell: Code:
boundaryField { shell_to_core { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; kappaMethod solidThermo; kappa kappa; Tnbr T; } sym1-shell { type symmetry; } sym2-shell { type symmetry; } outershell { type externalWallHeatFluxTemperature; mode coefficient; kappaMethod solidThermo; kappa kappa; Ta uniform 293.15; h uniform 100.0; value uniform 773.15; kappaName none; QrName none; } } Code:
( outershell { type wall; inGroups 1(wall); nFaces 788; startFace 18592; } sym1-shell { type symmetry; inGroups 1(symmetry); nFaces 320; startFace 19380; } sym2-shell { type symmetry; inGroups 1(symmetry); nFaces 320; startFace 19700; } shell_to_core { type mappedWall; inGroups 1(wall); nFaces 788; startFace 20020; sampleMode nearestPatchFace; sampleRegion core; samplePatch core_to_shell; } ) Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; } laplacianSchemes { default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default uncorrected; } Code:
solvers { "(h|e)" { solver PCG; preconditioner DIC; tolerance 0; relTol 0.001; maxIter 200; } "(h|e)Final" { $h; tolerance 0; relTol 0.001; maxIter 200; } } PIMPLE { nNonOrthogonalCorrectors 0; } relaxationFactors { equations { ".*" 1; } } One more piece of info: If I run the model for longer time, all three curves will converge to the same final Temperature. Last edited by Rustralia; July 14, 2020 at 16:33. |
July 4, 2020, 14:22 |
Rep Power: 5 |
Oh and this is check mesh info before it was split into two regions:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 6435 faces: 41775 internal faces: 39569 cells: 18366 faces per cell: 4.4290537 boundary patches: 5 point zones: 0 face zones: 3 cell zones: 2 Overall number of cells of each type: hexahedra: 0 prisms: 7880 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 10486 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outershell 788 427 ok (non-closed singly connected) sym1-shell 320 363 ok (non-closed singly connected) sym1-core 392 223 ok (non-closed singly connected) sym2-shell 320 363 ok (non-closed singly connected) sym2-core 386 220 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0001 0 0) (0.0001 0.0001 0.0001) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.0818631e-18 -2.9004236e-17 -4.2481159e-16) OK. Max cell openness = 2.1197891e-16 OK. Max aspect ratio = 4.2659031 OK. Minimum face area = 3.420192e-12. Maximum face area = 5.9869127e-11. Face area magnitudes OK. Min volume = 3.3910793e-18. Max volume = 2.8077274e-16. Total volume = 1.0435124e-12. Cell volumes OK. Mesh non-orthogonality Max: 49.726612 average: 13.776316 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.51786021 OK. Coupled point location match (average 0) OK. Mesh OK. Let me know if if you need more info to help out! Thanks! |
July 20, 2020, 03:49 |
#3 | |
Tobias Holzmann
Rep Power: 51 |
Hi, the first thing that is obvious is the following:
Mesh non-orthogonality Max: 49.726612 average: 13.776316 Quote:
Furthermore, many people are not aware how the numeric works and how the equations are solved » explicit and implicit terms. Are you sure that your energy equation is converged (even the explicit terms) within on time-step? The statement that FOAM needs a time-step which is much smaller compared to ANSYS is a hint that you do wrong things in the numerical stuff if the meshes are identical.
Keep foaming, Tobias Holzmann |
chtmultiregionfoam, heat transfer, solid |
Transient Simulation - Fluent remove my case and data | lape95 | FLUENT | 4 | April 22, 2020 09:20 |
Which terms to seach for: transient thermal multi case | RichardL | ANSYS | 1 | July 31, 2018 12:04 |
[OpenFOAM] post-processing chtMultiRegionFoam case in paraview? | phsieh2005 | ParaView | 2 | July 15, 2016 15:05 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Fluidisation transient case | Vikas Kumar | Main CFD Forum | 0 | April 24, 2003 03:29 |
