simpleReactingParcelFoam- same results for varying wallinteraction coeffs e aund mu |
April 17, 2018, 03:06 |
Jan Goebel
Rep Power: 17 |
Good morning everyone,
while using the simpleReactingParcelFoam- solver I figured out, that during the same amount of parcels injected into a vessel, the amount leaving through the outlets is not changing, even if I set the wall behaviour to stick. Normally choosing "stick"- option should cause, that particles touching the walls should remain inside the fluid domain, which is obviously not the case. Did anyone of you have the same problem ? Is there a good documentation available for the reactingCloud1Properties dict anywhre available- I've searched the web but couldn't find anything suitable. kind regards, Jan Last edited by jango; April 17, 2018 at 07:36. Reason: additional info added |
patchinteraction, simplereactingparcelfoam, wall adhesion, wall collision |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
'sample' utility for 'U' yields different results for simple-scotch-etc. | HakikiCanakkaleli | OpenFOAM Post-Processing | 3 | January 5, 2014 12:08 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
