May 27, 2018, 04:41 |
LES of Boundary-Layer
Syavash Asgari
Rep Power: 18 |
Dear Foamers,
I have been studying the spatial growth of ZPG boundary-layer using OpenFOAM LES. I have performed some simulations but the results are not very satisfactory. I wanted to share my results and my experience, hopefully someone will be interested and provide some hints to improve the results. In the first figure, a snapshot of the developing boundary-layer is observed (instantaneous x-velocity). I have used the Lund Recycling method, shared by Joachim on the forum: Lund Recycled Method for LES (flat plate) As for boundary conditions, for "U" I have applied inletOutlet and advective conditions at the top and outlet boundaries, respectively. For "p" I have applied a zeroGradient at both the inlet and outlet boundaries, as well as at the solid wall. At the top boundary, I have applied an outletInlet condition. I have used the dynamic version of Smagorinsky SGS model developed by Alberto Passalacqua: Improved implementation of dynamic Smagorinsky In the second figure, I have provided the evolution of friction velocity obtained through two distinct solvers: native pisoFoam and an explicit fractional-step method RK4. The friction velocity at the ref. station (shown by dash-line) is 0.0478 and 0.049 for piso and RK4, respectively. These values are overpredictions when compared to DNS at a similar Reynolds Number based on momentum thickness. piso solver: Re_theta = 1150 u_tau = 0.0478 RK4 solver: Re_theta = 1190 u_tau = 0.049 DNS (Jimenez et al, JFM 2010): Re_theta = 1100 u_tau = 0.0462 The domain length is 26,5,1.3038 in streamwise, wall-normal, and spanwise directions, respectively. As it is evident from the table above, the problem is the overprediction of friction velocity (u_tau). Also, shape of the mean velocity profile is different than DNS for both solvers. Of course, this correlates with the overpredicted friction velocity. I have tried to consider reasonable values for grid spacing as follows: dx+=50 dy+=1.0 with a growth ratio of 1.057 dz+=15 Now, to improve the results I have tried a combination of different stuff. Most notably was: 1-Double the size of spanwise domain, while keeping the dz+ the same--> no real improvement achieved 2-Double the size of spanwise domain with the same number of grid point (dz+=30)-->I have got better results. The friction velocity has reduced, but still away from DNS. 3-Double the number of streamwise grid points (dx+=25)--> Virtually the same results as step 2, i.e. an improvement was achieved and the friction velocity has reduced. According to my examination, the friction velocity (thus mean velocity profile) shows a dependency on the grid aspect ratio of dx/dz. This finding however needs to be confirmed by some other observations. Now, I would like to ask other people to share their opinions on this subject. Hopefully, a framework could be established based on which satisfactory boundary-layer LES will be carried out. Regards, Syavash |
June 3, 2018, 15:19 |
Syavash Asgari
Rep Power: 18 |
Well, I wanted to provide some update.
In the first figure attached, the normalized velocity profile at the same station marked by the dash-line in the original post (delta=0.84) is presented. Also, the normalized velocity profile is compared with two DNS studies in similar Reynolds numbers. It can be seen that the profiles substantially deviates from DNS in the log-law region. In the second figure attached, the same diagram is presented but for the refined mesh-in streamwise direction-with dx+=25. It can be observed that the results has significantly improved. I have not got the results for RK4 yet, so at the moment I can only upload the results for native pisoFoam. I hope these results will provide some hints for people who do LES using OpenFOAM. Regards, Syavash Last edited by syavash; June 4, 2018 at 08:44. |
June 28, 2018, 02:56 |
Syavash Asgari
Rep Power: 18 |
To provide a closure, I have attached the local mean velocity profile, as well as RMS of velocity fluctuations.
I have only provided the results of pisoFoam, as RK4 explicit solver has shown slight difference with data of DNS. Regards, Syavash |
May 16, 2023, 04:55 |
luofuqiang
Rep Power: 6 |
Thank you for shearing. Could you please introduce how to extract momentum thickness in OpenFOAM postProcessing?
May 19, 2023, 09:53 |
Syavash Asgari
Rep Power: 18 |
May 23, 2023, 10:01 |
#6 | |
luofuqiang
Rep Power: 6 |
https://github.com/syavash20/TurbLab...egralThickness Best Regards |
May 27, 2023, 20:52 |
#7 | |
luofuqiang
Rep Power: 6 |
I have compiled your code "integralThickness" in OF10, and it is functioning properly. However, I have two further questions that I'd like to inquire with you about. 1. Does the input field "Uvec" means "UMean/mag(U_0)"? 2. The theta result in my case has presented a negative value, which is most likely due to the fact that (1-Ux/U_0) is negative above the boundary layer. Therefore, what is the upper limit Y of the integration? may be the wall distance when U_x=U_0? Best regards. |
June 11, 2023, 05:00 |
#8 | |
Syavash Asgari
Rep Power: 18 |
Glad to know that the code is compiled on newer versions! In response to your questions, 1. Uvec is the span-wise averaged of UMean. If you have a long-enough time-averaged UMean, you can use it instead. 2. Note that both free-stream velocity and the integration height are hard-coded. The former is 1 and the latter was something like 2.xx! I guess this is why you are getting negative values. You may modify them as you see fit. Kind regards syavash |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
Boundary Layer roughness/ low reynolds wall treatment | Luigi_ | STAR-CCM+ | 1 | March 14, 2012 08:40 |
