Is there any test case to test turbulence modelling for two phase flow? |
August 22, 2019, 05:28 |
krishna kant
Rep Power: 10 |
Hello All
I am looking for a test case for to verify turbulence model in a two phase flow system. I have spent hours for the same. Can anyone suggest one ? |
October 10, 2019, 07:55 |
Rep Power: 13 |
Are you talking about a test case that uses bubble induced turbulence model that is programmed into an Euler-Euler solver? I'm not aware of any..
There is the kOmegaSSTSato for example that you can try to use for experimental data that maybe can be found online.. |
October 11, 2019, 04:34 |
krishna kant
Rep Power: 10 |
Hello
Thanks for the reply. My aim is to solve atomization problems in two phase flow. Since turbulence instability of the liquid jet plays a major role in the breakup. I am looking for some standard test case for analyzing turbulence instability of my solver. One way is to validate it with experimental data available for jet break up. But since it is going to be a validation for the solver so I am looking for a standard numerical test case for analyzing turbulence instability in two phase system. And yes the solver is Euler-Euler solver similar to s-CLSVOFFoam. |
[OpenFOAM.com] Installing on Ubuntu 18.04 | samiam1000 | OpenFOAM Installation | 11 | April 27, 2020 00:01 |
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 2 | April 20, 2020 13:50 |
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background | pchoopanya | Main CFD Forum | 4 | May 10, 2018 11:05 |
2 phase flow validation on this case. | Ash Kot | Fluent Multiphase | 0 | May 31, 2017 03:11 |
The turbulent swirling flow test case - Dellenback | dogan | Main CFD Forum | 0 | February 27, 2013 08:10 |
