Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Docker naca0012 validation
Old   January 1, 2021, 19:55
Default Docker naca0012 validation
Ivan
Ivangzp is on a distinguished road
Hello everyone,
I'm trying to validate a well-known case, turbulent flow over NACA0012. Information of the validation ca be found here: https://turbmodels.larc.nasa.gov/naca0012_val.html
I simulated properly the case with the version of OpenFoam v2006, obtaining succefull results. I can say that I validated the case because I got accuracy values for Cl and Cd for differents angles of attacks (0º, 3º, 6º, 9º, 12º and 15º). I did that with two different turbulence models (RAS-Spalart Allmaras and RAS-KwSST) using the solver simpleFoam.
The problem is the following one. I tried to run the SAME case with a version of OpenFoam installed by means of Docker. (IN THE SAME LAPTOP).
Both are supposed to be the same version but the results are differents (Relative error 30 %) and it isn't related with the time of convergence.
Has anyone suspect where can be the problem?
If someone is interested in look over the code, the case for AoA 3 degrees is here:
https://drive.google.com/file/d/1p2P...ew?usp=sharing
The case is ready to run with simpleFoam.
Thank for your time.
Ivangzp is offline   Reply With Quote
Old   January 2, 2021, 05:36
Domenico Lahaye
dlahaye is on a distinguished road
Make sure mesh and solver setting are equal.
dlahaye is offline   Reply With Quote
Old   January 2, 2021, 06:05
Ivan
Thank you very much for the reply.
They are the same file. (Copy and paste)
That’s the crazy thing.
Old   January 2, 2021, 19:22
Ivan
I'm sure it is related with the solver.
Where I can find the defualt values that OF uses?
I'm searching in the libraries, but I didn't find anything which could fix it
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 11:18
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 02:58
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 19:00
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 10:22
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
