Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Validatation NACA 0012 OFv2006 lack of precision
Old   January 8, 2021, 06:55
Question Validation NACA 0012 OFv2006 lack of precision
Ivan
Ivangzp is on a distinguished road
Hi everyone,
I'm using OpenFoamv2006.
I'm trying to validate the case "Turbulent flow over NACA0012 airfoil (2D)". Basically, it's a NACA0012 with Re of 6*10^6.
The details of the case can be found in: https://www.openfoam.com/documentati...irfoil-2d.html
I'm focus on the lift coefficient. I tried the AoA [3,6,9,12].
Usually, The results are deviated around 10 % of the real ones. To show that, in case AoA of 3 and 6:
Cl (3) [Real] = 0.3234
Cl (3) [obtained = 0.2991
Cl (6) [Real] = 0.6648
Cl (6) [obtained = 0.59627
I tried two differents turbulent models, Spalart-Allmaras and KwSST and the results are quite similar.
I have some experience meshing. I tried at least 6 different meshes, because usually the error it's there, but the results doesn't improve (2-3 % of change).
About how I calculated the force:
force{
pitchAxis (0 0 1);
magUInf 1.0;
rhoName rhoInf;
rhoInf 1.0;
patches (wallS);
// wallS is the patch who represent the NACA profile.
CofR (0 0 0);
liftDir (-0 1 0);
lRef 1.;
writeControl timeStep;
Aref 1.;
UName U;
pName p;
U U;
rho rhoInf;
p p;
libs ("libforces.so");
dragDir (1 0 0);
type forceCoeffs;
writeInterval 1;
I attached the case just in case anyone one to glance at it.
https://drive.google.com/file/d/1p2P...pWkuxhT4y/view
It's ready to be run with "simpleFoam".
Any kind of help is more than welcome.
Thank for your time.
Ivangzp is offline   Reply With Quote
Old   January 10, 2021, 13:14
mzzmrt is on a distinguished road
You have to declare lift and drag direction accordingly as in the flow vector direction, this is your main problem in your setup.
I have tested your case with this direction correction and got Cl (3) = 0.326 just in a few hundred steps.
mzzmrt is offline   Reply With Quote
Old   January 10, 2021, 13:35
Ivan
First of all, thank you so much por replying.
I tried that and it didn't work.
I usually project the values of Cl and Cd, after obtaining from OpenFoam, to get the "real ones", in that way I don't have to change the direction of Lift and Drag all the time.
For example, for 3:
Cl (real) = Cl* cos(3)-Cd*SENO(3), being Cl* and Cd*, the values obtained in OpenFoam.
Let me ask you 2 question:
- Just in case, which direction have you declared for lift and drag ? (copy and paste from the controlDict, would be awesome).
- Which version of OF have you used?
I asked you that, because with the same setting in OpenFoam4.0, I have the "correct" result, really close to Cl (3) = 0.326.
Old   January 11, 2021, 03:22
I have only changed this line:
dragDir (1 0 0);
with this:
dragDir (0.998629534754574 0.0523359562429438 0);
to test your setup.
it must also be changed the following line accordingly indeed:
liftDir (-0 1 0);
with
liftDir (0.0523359562429438 0.998629534754574 0);
and yes, I have used OF4.1!
naca0012, openfoamv2006, precission, turbulence, validation
Single v.s. double precision Confused CFX 15 November 10, 2016 05:42
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 14:01
Data for NACA 0012 Muntazir Main CFD Forum 0 February 5, 2012 07:09
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 11:38
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
