Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
CLSVOF - for capillary rise
Old   March 28, 2019, 06:39
Default CLSVOF - for capillary rise
K
kuria is on a distinguished road
Hey Foamers
I created a CLSVOF solver based on the tutorial from Chalmers : http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf
My thought was to use the solver to model a capillary rise, but I have not managed to model it properly.
I used the default case available in openfoam - capillary rise as the starting point to create the case file, I added the boundary condition file for level set function (which I called the PHI_LS).
When I run this model, I get very unrealistic results, - water column drops (instead of rising).
Inorder to ensure that its not anything to do with case files (alpha1, p_rgh and U BC and other solver related stuff), I ran the case with interFoam and it behaves as expected.
So I am guessing CLSVOF method is behaving weirdly becasue of some boundary condition associated with the level set function (PHI_LS).
Can some help me out or point out what I did wrong?
Any help would be greatly appreciated!
BR
Kurian
Last edited by kuria; April 9, 2019 at 09:24. Reason: Changed the framing of question/problem
kuria is offline   Reply With Quote
Old   July 28, 2020, 22:27
John
thintn222 is on a distinguished road
Hi kuria, I'm sorry because it has been a while since you posted this. But I also got the same result with this problem that the water column drop instead of rising. Have you figure out what problem happen in this case, or in this solver?. Thank you so much!
thintn222 is offline   Reply With Quote
Old   July 30, 2020, 03:56
K
Hey John
Unfortunately, I could not figure out what went wrong with the CLSVOF. So I started on working on another way to reduce spurious velocities.
Old   July 5, 2021, 11:39
XinZhou
XinXin is on a distinguished road
Hi kuria, What kind of method do you use to reduce spurious velocities
XinXin is offline   Reply With Quote
Old   July 12, 2021, 07:40
Amirhossein Taran
amirhosseintaran is on a distinguished road
Hi kurian ,
The model i think you are using , is highly dependent on the mesh uniformity. I mean your mesh needs to have same dx,dy and dz.
make sure you checked this point.
Regards.
Amir
amirhosseintaran is offline   Reply With Quote
capillary rise, clsvof
Axial flow fan incorrect pressure rise yambanshee OpenFOAM Running, Solving & CFD 2 June 25, 2020 14:05
Closed volume pressure rise with temperature rise vinayak4399 FLUENT 10 March 11, 2020 08:29
Rise of temperature in a thin film by electric potential SofiG System Analysis 0 January 21, 2019 04:41
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
temperature rise due to viscous dissipation Marek Main CFD Forum 6 December 30, 2004 16:24
