chtMulitRegionSimpleFoam—difference result for useImplicit |
Tens
Rep Power: 0 ![]() |
I used chtMulitRegionSimpleFoam in OpenFOAM-v2112, and found that whether the useImplicit is true or not has a significant impact on the results.
When the useImplicit was false, I got a higher temperature which is close to the result of Fluent.But when the useImplicit was true, I got a lower temperature. The point is using Implicit spending less time than not using it, usually a dozen times faster. 1.Why does useImplicit have such a big impact on the results? 2.How to get more accurate results in less time? |
Lei Zhou
Rep Power: 5 ![]() |
Hello, Do you have solved the problem or find why this happening?
Dasarathan Sampath
"useImplicit - true" will help the solver to converge the temperature quickly when you have cyclic, cyclicAMI, cyclicACMI, and mapped boundary conditions.
When you set "useImplicit - true" and parallel run, you must have your coupled patches on the same processor. It will not affect your results, and you should get the same result with "useImplicit - true" & "useImplicit - false." |
Display Modes | |
how use the result data as initial data | n4a0505 | OpenFOAM Post-Processing | 1 | March 4, 2015 02:01 |
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 | wan11 | CFX | 3 | December 18, 2014 19:25 |
Result output chart | YaX | CFX | 4 | July 10, 2014 18:47 |
bad result output | junarzt | OpenFOAM Running, Solving & CFD | 0 | March 19, 2014 10:40 |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
