Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Vertical profiles of k not conserved for the case atmDownstreamDevelopment
Old   May 13, 2025, 16:43
Default Vertical profiles of k not conserved for the case atmDownstreamDevelopment
Raffaella
raffara2 is on a distinguished road
The tutorial verificationAndValidation/atmosphericModels/atmDownstreamDevelopment (OpenFOAM version 2312) should verify that in conditions of horizontal homogeneity, all the fields are conserved from the inlet across the domain up to the outlet. I made a simulation without changing any condition and the results seem to me quite surprising. While the velocity profiles are indeed conserved from the inlet across the domain, the vertical profiles of k are far from conserved, and most notably, a large peak close to the ground appears downwind, while the inlet condition is an uniform vertical profile. This seems inconsistent with both the articles cited in the case, that is, Hargreaves and Wright 2007 (vertically homogeneous profiles, conserved across the x-domain), and Sogachev2006 (vertically inhomogeneous profiles, but conserved across the x-domain). Has anyone performed simulations starting from this case? Does anyone have suggestions about how to overcome this issue? In the attached figure, the vertical profiles at the last iteration of the simulation (5000), comparing profiles at inlet, x=1000, x = 4950, and outlet. Thanks in advance for any feedback!
raffara2 is offline   Reply With Quote
Old   November 13, 2025, 11:39
reweny is on a distinguished road
Did you mange to fix this? I am also wondering the same!
reweny is offline   Reply With Quote
Changing the grid on the same set-up Katya FLUENT 9 June 6, 2025 04:21
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 10:50
