Older versions compatibility (1.5 vs 2.1) ?
Hi!
A friend is trying to use an OpenFOAM project that was done with an old version (1.5-dev). As the current version is 2.1, I wonder, how is it with compatibility? Should we try to use 1.6? OR is 2.1 compatible enough? Regards, David |
Greetings David and welcome to the forum!
Mmm... 1.5-dev is a variant of OpenFOAM, so the direct relative is 1.6-ext: http://www.extend-project.de/ In other words, it really depends on what features you're trying to use. Best regards, Bruno |
Thanks, they opted for installing the exact same version as the original project used.
(it is still available in a Ubuntu PPA...) Regards, David |
