May 30, 2012, 06:18 |
Conjugate heat transfer in reacting flow
Alireza
Rep Power: 15 |
Hi Friends
I'm a Ph.D. student majoring in mechanical engineering, working on “Unsteady Conjugate Heat Transfer in reacting flow”. I faced some questions about OpenFOAM. I’d be so thankful if you could help me. 1. Does OpenFOAM solve this problem (Unsteady Conjugate Heat Transfer in reacting flow)? 2. Which algorithms does OpenFOAM use for conjugate heat transfer? With Kind Regards |
May 30, 2012, 14:15 |
Nima Samkhaniani
Rep Power: 24 |
Hi Dear ali reza
no, it has reacting flow solver (many different combustion model) and conjugate heat transfer solver but you need coding to reach what you want! |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Conjugate Heat Transfer | boathead | STAR-CCM+ | 1 | April 15, 2011 09:13 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
